Steer Kit Moog or XRF
Old Jul 4, 2020 | 10:14 AM
phils69's Avatar
phils69
I am going to replace my steering linkage to see if it helps my steering issue. I have seen good comments on here about the XRF kit but I normally use Moog. The XRF kit through Ebay is $300. I used a diagram I found on here showing the Moog part numbers and Rock Auto has these parts including shipping for $313. The price is almost the same. Would I be good with either one of these? Rock Auto would probaly get to me first.
Old Jul 4, 2020 | 01:52 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
XRF or Spicer are the only ones I prefer to choose between for suspension and steering parts. Sometimes I need to deviate from that because time is not on my side.
Old Jul 4, 2020 | 02:37 PM
Brian Hanks's Avatar
Brian Hanks
Sous is steering you (see what I did there) in the right direction. Moog quality just isn’t what it was. They are still living off their name but as the failures mount up it is just a matter of time before people will abandon ship. Sad but true. They seem to still make some things quality but it is very hit or miss.
Old Jul 4, 2020 | 02:41 PM
00Dave's Avatar
00Dave
I have had great luck with my XRF components. I cannot comment on others due to no personal experience.
Old Jul 4, 2020 | 02:52 PM
jstihl's Avatar
jstihl
I think the xrf kit on eBay was from Canada. If that one ends up being too much shipping here's one for $319 https://dkdiesel.com/i-30511639-xrf-...rsion-4x4.html
I just ordered this one and the quality seems great but I have yet to install it
Old Jul 4, 2020 | 03:38 PM
phils69's Avatar
phils69
Nuff said. XRF it is. Thanks
Old Jul 4, 2020 | 04:02 PM
00Dave's Avatar
00Dave
Curious if you have a steering damper? Looks like a shock attached to the linkage.
Old Jul 4, 2020 | 04:05 PM
Sous's Avatar
Sous
FTE Emeritus
Details on the steering damper which can be relocated from the OEM linkage to the XRF linkage if required.
https://www.ford-trucks.com/forums/1...installed.html
Old Jul 5, 2020 | 09:00 AM
phils69's Avatar
phils69
Yes I have a dampner, replaced it last year with a better one. Thanks for the link Sous.
Campbellsoutlaw
Aug 26, 2019 02:51 PM
FlaresideJack
Mar 7, 2010 09:19 PM
77whiteF250
Jul 26, 2005 09:50 PM
