Yep... another no-start thread
Old Jul 11, 2020 | 01:49 PM
  #61
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Also, just for future readers... What is a good reading between pins 90 and 91 and what were you seeing that led you to the CPS?
Old Jul 11, 2020 | 01:55 PM
  #62
ztodd377's Avatar
ztodd377
Originally Posted by Sous
So, a failed CPS was stopping the 5v reference from transmitting data to the PCM which caused the PCM to act like it had failed by not lighting the WTS lamp?
Is that what you are saying?
Thats what it appears. With the bad CPS I was getting 398mV between pins 90 & 91. With the good CPS the reading changed to 5.02V. It should be between 4 & 6 volts.
I just felt like I was getting deeper and deeper and when rewording the wirings diagrams, the vref runs from pin 90 through pin 21 of the 42-pin connector right to the CPS. I felt it couldn’t hurt to swap it out with the one I had from Clay.
Old Jul 11, 2020 | 02:09 PM
  #63
Sous's Avatar
Sous
FTE Emeritus
First time I have seen that issue and resolution. I commend you for your efforts and congratulate you on your victory.
Tell us... Do you do a victory yell when it fired up? I know I would have.
Old Jul 11, 2020 | 02:10 PM
  #64
ztodd377's Avatar
ztodd377
Put the hydra chip in, truck ran for about 30 seconds then died. No restart. Pulling the PCM to check the connections. I wiped down the pins with alcohol and let it dry before putting the hydra on and it felt like a solid connection. We’ll see.
Old Jul 11, 2020 | 02:14 PM
  #65
ztodd377's Avatar
ztodd377
I did! Until I put the hydra in and won’t start again. Then a loud “wtf”.
Old Jul 11, 2020 | 02:35 PM
  #66
M3rc's Avatar
M3rc
Is there maybe a short in the CPS pigtail that by replacing the CPS you jiggled it?
Old Jul 11, 2020 | 02:55 PM
  #67
ztodd377's Avatar
ztodd377
Thats what I’m thinking. I’m pulling the wiring now and am going to check continuity when I find where the other ends connect. I know one goes to the 42-pin connector. I have a spare pigtail that I’ll put on if continuity checks out. Maybe this one has outlived its usefulness.
Old Jul 11, 2020 | 03:26 PM
  #68
ztodd377's Avatar
ztodd377
All 3 go to the 42-pin connector. I have good continuity between the pigtail pins and the 42-pin connector. I have good continuity between the 42-pin and the corresponding pins of the PCM (21, 65, 90). When the 42-pin is connected I get an ohm reading when going from the pigtail to the PCM.
Old Jul 11, 2020 | 04:24 PM
  #69
ztodd377's Avatar
ztodd377
Does anyone recall what the CPS ohm readings are supposed to be? I can’t find them anywhere.
Old Jul 11, 2020 | 04:39 PM
  #70
M3rc's Avatar
M3rc
Don't know if this helps but here's a link to riffraff CPS PDF https://www.riffraffdiesel.com/conte...d0QlBvhA-JyShY which has a troubleshooting diagram at the bottom.
Old Jul 11, 2020 | 05:36 PM
  #71
ztodd377's Avatar
ztodd377
Plugged in the MX+ to check for codes and it says the scanner is communicating with the phone but not the vehicle with the key on. Checked the ground pins in the OBD II connector and they’re good. Check that I’m getting 12V at pin 16. It’s good. Back to the schematics.
Anyone have a schematic of the OBD II port to PCM? Maybe I have a short somewhere there. There truck started and ran again, then I shut it off and tried to connect the scan tool. Wouldn’t communicate and now back to no start.
Old Jul 11, 2020 | 07:51 PM
  #72
AllaboutMPG's Avatar
AllaboutMPG
Well congrats on figuring it out the first time.
did you leave the old PCM in the truck. Any chance it's bad and sending higher voltage on the v ref line and frying the CPS? Just spit balling now.
does disconnecting the CPS change anything
Old Jul 11, 2020 | 09:39 PM
  #73
ztodd377's Avatar
ztodd377
I did leave the old PCM in the truck. I unplugged the CPS to check resistance between it and the PCM. Before I unplugged it the vref was at something low like 1.75 volts. When I plugged the CPS connector back in I saw vref of 5.01 volts. Right where it should be.
Im thinking the plug may have an intermittent connection. I’m working on replacing the plug now, just on a beer break. Hopefully that will fix it but I’m not betting any large sums of money on it.
Will report back when I have the new plug soldered on the reconnected.
As a side note, when I replugged the CPS connector I had the PCM connected outside the truck in the wheel well. Truck fired right up. Disconnected batteries, moved PCM to its normal home, reconnected batteries and no WTS, no fuel pressure. This is definitely a stumper.
If I can get it figured out I’ll drive it home and troubleshoot more; hopefully it makes the 6hour journey.
Old Jul 11, 2020 | 10:19 PM
  #74
AllaboutMPG
Really seems like a wiring issue near the PCM
Old Jul 11, 2020 | 10:30 PM
  #75
RacinJasonWV's Avatar
RacinJasonWV
My thoughts as well. Moving the PCM connected the short. Moving it back broke the connection again.
