Yep... another no-start thread
Old Jul 4, 2020 | 02:48 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
From your first post above, these two items are the ones that concern me the most...
-No fuel pressure
-No WTS light
Old Jul 4, 2020 | 02:59 PM
Sous's Avatar
Sous
FTE Emeritus
I just reread your first post twice to make sure I could not think of anything else that you have not done.
Do you have a scan tool that you can try and see if the PCM is responsive? That is a long shot, but worth a shot if you have a scan tool.
I am looking through the Ford Service Manual PC/ED pinpoint tests for something that may be useful. If I find something, I will attach it in a follow up post.
Old Jul 4, 2020 | 03:04 PM
Sous's Avatar
Sous
FTE Emeritus
This is the only pinpoint test that I saw that may be relevant to what you are going through.
File Type: pdf
Old Jul 4, 2020 | 03:21 PM
ztodd377's Avatar
ztodd377
I emailed dieseltechchatt but I think they're closed until Monday. I didn't see a phone number on their website. I also called autocomputerexchange.com and they have one in stock plus a 7.3 test engine they test all their PCM's on before sending out. It's $699 (includes the $200 core charge) and I can pay another $100 for lifetime warranty (which to me is peace of mind insurance). I would just like to find out what caused it to die.
Old Jul 4, 2020 | 04:22 PM
ztodd377's Avatar
ztodd377
Ordered the new PCM, should be here by Thursday. We're going to get a rental car and drive back to Tucson so I can work next week and then we'll drive back next weekend with the wife's car to fix my truck. Went ahead and ordered a Hydra from Clay to install with the new PCM.
Old Jul 4, 2020 | 04:33 PM
Sous's Avatar
Sous
FTE Emeritus
Good call on the Hydra.
Did you end up going through autocomputerexchange.com for the PCM? If so, please be sure to post up a detailed opinion on their service and product. DTC is a fairly new and trusted source to us 7.3'rs and it doesn't hurt to have other options.
I hope this is your issue sir.
Old Jul 4, 2020 | 07:20 PM
ztodd377's Avatar
ztodd377
I hope it is too. I’m planning to run through that diagnostic you attached earlier a bit later this evening. I’ll post up opinions and experience.
Old Jul 5, 2020 | 01:58 PM
ztodd377's Avatar
ztodd377
Started running through the PCM reset diagnostic you sent Sous. With PCM out and checking at the pins of the plug, ME1 checks out. Move to ME2, no vref voltage.
It says at the top to use a breakout box but all I can do is test at the harness pins with the PCM out. I’m hoping that’s ok. It directs me to ME5 where I’m checking for resistance of less that 5 ohms across puns 91 to pins 25, 76 (which is an empty hole), 77, & 103. I get 109.5k ohms, way above 5 ohms.
Now I’m wondering if I have an open somewhere that caused the PCM to die or if I really need the breakout box to actually test the PCM and not just the harness.
Hopefully the new PCM fixes the issue and whatever caused its death doesn’t happen again.
Old Jul 5, 2020 | 02:23 PM
FordTruckNoob's Avatar
FordTruckNoob
You can use this technique to backprobe the PCM connector.
Or you can get probes like these:
Lisle 64900 17-Piece Back Probe and Alligator Clip Set
Amazon Amazon
Old Jul 6, 2020 | 02:06 PM
ztodd377's Avatar
ztodd377
Is it just the PCM connector I'm back probing or the PCM itself while it's plugged in to the connector?
Old Jul 6, 2020 | 02:15 PM
FordTruckNoob
The connector while the PCM is plugged in. I'm thinking the procedure is asking you to measure values with the PCM plugged in if it's telling you to use a breakout box.
Old Jul 6, 2020 | 05:08 PM
ztodd377's Avatar
ztodd377
I’m gonna buy those probes and plug in the old PCM and test. I’m back In Tucson until the end of the week then will be driving back to Albuquerque on Friday to work on the truck.
I’d really like figure out what caused it to die before I plug in the new one.
Old Jul 10, 2020 | 07:44 PM
  #28
ztodd377's Avatar
ztodd377
Completed the 6 hour trip from Tucson to Albuquerque today. Diving back into the truck. The new PCM arrived today. I’ll post pics in a bit, but it appears the lifetime warranty wasn’t worth the money. If you open the case at all it voids any warranty.
Im going to plug in and back probe the old PCM to see if I can find why it died. Dieseltechchatt also emailed me back and told me to try unplugging and replugging the EBP sensor, said sometimes that clears it.
After I backprobe the old PCM I’ll plug in the new PCM untouched and see if it works before I go installing the hydra on it.
I’ll update in a bit.
Old Jul 10, 2020 | 09:11 PM
  #29
ztodd377's Avatar
ztodd377
Still no start!
Well, backprobing proved unsuccessful as the space is too tight even with the power distribution box moved over.
Put the new PCM in and still doesn’t start. Same exact symptoms as before.
Engine turns over rapidly but no WTS light, no GP activation and no fuel pressure. I’m at a loss here gents.
OBD II reader will not connect either, to old or new PCM.
Old Jul 10, 2020 | 09:22 PM
  #30
Sous's Avatar
Sous
FTE Emeritus
Is it possible the connections for the PCM on the engine side are loose or not making contact?
What do the female pins on the PCM harness passthrough look like, are they clean?
I know you said you checked the power points, but I am at a loss too, so just thinking outloud here...
