1972 Ford FE 360 Starter problems
Old Jul 2, 2020 | 03:34 PM
Sayler99's Avatar
Sayler99
I am currently trying to put my motor back together to hear it run for the first time since owning it. I have a set of hooker headers that I am trying to put on got the driver side put on but I can't seem to get my passenger side one on. I took off the starter and I can get the header in place but can't get the starter back into place. Anyone got any ideas on how to get it done? Also has anyone ran the mini starters that are available and if anyone has any links to them that would be much appreciated!!
Old Jul 2, 2020 | 04:19 PM
ford390gashog's Avatar
ford390gashog
You will need a mini high torque starter with a heat shield wrap. I bought mine from DB electric.
Old Jul 2, 2020 | 04:28 PM
Sayler99's Avatar
Sayler99
I don’t see any for a 360 will the one for a 302 work becauseI see that’s all they have from what I’m seeing?
Old Jul 2, 2020 | 06:45 PM
GPatrick's Avatar
GPatrick
On mine, with different header manufacturer, I had to unbolt the passenger side motor mount, jack the motor up, and install the starter and header at the same time. Not fun by yourself and you have to repeat the exercise if you need to change the starter. My 4R70W conversion included a mini-starter that I can r&r without loosening the headers. I'd upgrade the starter now when you can get to it.
Many listings for starters and other components only show for the 390 on certain sites. The 360 and 390 share the same starter.
Old Jul 3, 2020 | 07:14 AM
stpackard's Avatar
stpackard
I just put the power master 9506M on, runs great and clears headers well. Don’t get the 9506, it has clearance and terminal issues with it being on the block side. I’ve had a great experience with this one and their customer support is excellent.
Old Jul 3, 2020 | 07:16 AM
stpackard's Avatar
stpackard
Forgot to add that it says it’s for a 427fe, but I’m running it on a 390 with sanderson headers.
Old Jul 3, 2020 | 06:20 PM
Sayler99's Avatar
Sayler99
Anyone know a good place to get battery wires since I will have to rerun the cables to the new solenoid?
notyettoday
Jan 8, 2020 12:23 PM
FLgargoyle
Mar 3, 2014 08:42 AM
dogsniper
Feb 18, 2008 10:21 PM
rcbisset
Dec 18, 2002 08:43 PM
