Won’t start
Old Jul 1, 2020 | 10:15 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Taken from the Oregon Fuel Injection site...
  1. RPM, minimum 100 rpm cranking speed (When warm it should be over 180 rpm)
  2. ICP, minimum required for starting 500 PSI if no rpm signal, ICP won’t go over 400 PSI
  3. Voltage during cranking 7-10 volts minimum depending on year
  4. Pulse Width; 0 ms means no sync, 1994-1997 .42 ms indicates that PCM and IDM are in sync (on 99-03 it should be .60 ms) and the PCM is waiting on the ICP to reach the minimum of 500 PSI. When min. ICP is reached PW should change to 1-6 ms
  5. If any of the above doesn’t meet the minimum specification, solve the problem as-per the appropriate Ford Diagnostic Manual.
Old Jul 6, 2020 | 12:41 AM
wtroger's Avatar
wtroger
New ipr will be here Tuesday. Will install and see whart happens
Old Jul 6, 2020 | 07:40 AM
tommyl's Avatar
tommyl
Check your wiring over drivers side valve cover for chafing>
Old Jul 8, 2020 | 07:42 PM
wtroger's Avatar
wtroger
Changed ipr put on a new motorcraft. Still no start. I am going to try and attach screen shots of my Forscan dashboard.
Old Jul 8, 2020 | 07:58 PM
jstihl's Avatar
jstihl
You still have pretty low cranking RPMs. Do you know what your cranking voltage is?
Old Jul 9, 2020 | 07:36 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
can you get a video of it turning over so we can hear the cranking and condition of starter?
Old Jul 10, 2020 | 12:12 AM
wtroger's Avatar
wtroger
Changed starter and she fired up. Thanks for all the help
Old Jul 10, 2020 | 06:22 AM
jstihl's Avatar
jstihl
Good deal , glad you got it running
Old Jul 10, 2020 | 06:27 AM
AllaboutMPG's Avatar
AllaboutMPG
That's excellent news.
Old Jul 10, 2020 | 06:52 AM
KubotaOrange76
awesome!!!
Old Jul 10, 2020 | 07:39 AM
Sous's Avatar
Sous
FTE Emeritus
Great news!
Just for comparison sake, monitor the same PIDs as in the image above and see what they are. This will give you a baseline of what your truck is looking for and probably show the RPM up near 200.
Let us know what you find if you do this.
TSBAHRS
13
Jul 19, 2019 12:48 PM
jepoycat95
27
Sep 25, 2018 08:49 AM
fordpride
2004 - 2008 F150
Mar 11, 2016 02:04 PM
1978Crew
Sep 29, 2011 11:20 PM
fordstaf
Apr 14, 2010 12:15 PM
