I'm having a strange issue with my door lock which started after I did the keypad install. The drivers door does not latch when ever I drive the truck , stop and get out then try to shut it again. If I hit lock and unlock it latches normally again. Afterwards the door functions and latches normally while parked.
Any ideas?
I would try uninstalling the key pad to see if that fixes the problem. The Key pad could be bad or installed incorrectly.
