electric door locks
Old Nov 24, 2003 | 04:15 PM
oldscout's Avatar
oldscout
electric door locks
I have a 99 SD. The door locks try and lock or unlock. You can see the door indicators try and suck down if up, and try to push up if locked. If you lock the passenger door the drivers door will lock. This will not appen if the drives door is locked the passenger door will not lock. If you actuate the switch several times them nothing will happen. Does not matter if the engine is running or not.
Old Jan 20, 2004 | 01:41 PM
boardin111's Avatar
boardin111
i have 2000 f150 and i had the problem with both doors. it was the door lock acuators that to be replaced
