Injector questions.
Old Jun 24, 2020 | 03:29 PM
Adamsbombs's Avatar
Adamsbombs
Injector questions.
My first diesel. Ford dealership says I need 8 new injectors. I took it in with a miss and now it won't even go 55 miles an hour and will barely start. How can I verify what they're saying.?
Old Jun 24, 2020 | 03:46 PM
Syphlyn's Avatar
Syphlyn
DO NOT BUY 8 INJECTORS.
There are people here who are better with describing how to checkl but your issues could be any of the following
Bad fuel pressure (regulator spring, leak, pump, filters)
A bad injector seal
High pressure oil system issue (small leak or pump failing)
One or more failed injectors
Bad ficm (which can be caused by a failing alternator/batteries)
Don't throw $3k away on injectors to only find out its your ficm ect...
Check the tech folder and read how to check things I list aboved.
https://www.ford-trucks.com/forums/3...ch-folder.html
Old Jun 24, 2020 | 03:48 PM
Syphlyn's Avatar
Syphlyn
Give us some more details...
Year
mileage
deleted? studded? tuned? ect...
ALL the data/info you have
Old Jun 24, 2020 | 06:22 PM
Adamsbombs's Avatar
Adamsbombs
04 with a bully dog. It is studded. That's the only thing that I can tell for sure. It still has EGR. Ford told me that the head pressure was fine. I really don't believe it needs 8 injectors. I had the truck scanned at a couple of other places. Every time they would tell me different injectors were not firing. Only one or two though. Since I got it back from Ford it will hardly run. I don't know what they done to it, but I had put ten thousand miles on it towing an enclosed trailer before I took it to them.
Old Jun 24, 2020 | 06:44 PM
bismic's Avatar
bismic
You need a good scan tool and code reader. Suggest ForScan on a smartphone or a laptop.
Post the codes as a start
Old Jun 24, 2020 | 07:42 PM
2006powerstroke90's Avatar
2006powerstroke90
Without codes and mileage it’s hard to say what you may need.
depending on mileage and the amount of injectors not working properly....if it were my truck I’d do them all.
if it needed 2 on one bank I’d most definitely do all 4.
Old Jun 25, 2020 | 07:51 AM
xcrsp440's Avatar
xcrsp440
When you get injectors, only go with Ford remanufactured. They seem to have the best history and can be found for around $180 if you shop around.
Old Jun 25, 2020 | 09:07 AM
Adamsbombs's Avatar
Adamsbombs
Any way to test them after they're out of the truck?
bulldog88
Feb 28, 2015 04:34 AM
77F250Diesel
May 24, 2009 07:56 PM
jkidd_39
35
Mar 17, 2009 12:23 AM
bf250
Mar 5, 2006 08:25 AM
powerstrokin95
Oct 25, 2004 02:10 PM
