Sponsored by: Real Truck
Starter clunks
Old Jun 21, 2020 | 12:10 PM
Loftatsea's Avatar
Loftatsea
Starter clunks
2000 F450 with a 7.3. Truck wouldn't start a few weeks ago. Just got a clunk sound from the starter. I tried jumping the starter and got it running. I tired starting it a few times after that and had no problem. The next morning I got the same no start, just a clunk at the starter. I replaced the starter but it still wouldn't start. Replaced the relay on the fender and it started right up. Started fine for a weeks then the same clunk. Tried jumping the fender relay and the starter. Nothing. Was ready to hit the starter and it started by turning the key. I didn't want to take a chance so I replaced the starter again. Still getting the clunk, no start. Removed the starter and bench tested it; it was fine. Checked and cleaned up all my grounds. Still nothing. To summarize, nothing but a clunk when I try to start it by turning the key, jumping the fender relay or jumping the starter. Connections have been cleaned. I'm thinking of a bad cable with corrosion in the middle of it somewhere? Someone else I was talking to said it could be a bad ignition switch. Any thoughts?
Old Jun 21, 2020 | 08:55 PM
projectSHO89's Avatar
projectSHO89
If it was the ignition switch, it wouldn't do anything.
Voltage drop test your cables. Sounds like your battery system cannot provide enough current for the starter motor to crank the beast.
Old Jun 24, 2020 | 06:18 AM
Loftatsea's Avatar
Loftatsea
Turned out to be the cable going into the positive battery terminal. She seems to be good now.
Follmerpa
Jan 22, 2019 09:11 PM
green_95
Jan 17, 2019 08:30 AM
ernsppw
Jan 4, 2019 09:25 AM
giorgio.fo
May 11, 2016 08:46 PM
StevensPoint
Nov 26, 2008 03:24 PM
