Replaced starter still wont start - Ford Truck Enthusiasts Forums
Old 01-20-2019, 07:12 PM
Follmerpa
Follmerpa is offline
Follmerpa is starting off with a positive reputation.
My starter was starting to go on my 96 5.8 it was suggested replace the starter relay or solenoid well that didnt work so i put in new starter today. It will crank when i cross the terminals on the solinoid but i get nothing when i turn the key???
Any thoughts or suggestions
Thank you
Old 01-20-2019, 07:56 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is online now
My4Fordtrucks is gaining momentum as a positive member of FTE.My4Fordtrucks is gaining momentum as a positive member of FTE.
Have you checked the ignition switch? If it starts when you jump the terminals on the solenoid why would you replace the starter?
Old 01-20-2019, 08:27 PM
Follmerpa
When i crossed the terminals on old relay started did nothing replaced relay starter still did nothing so i figure my starter is bad. Now i dont know what to do. Where is ignition switch?
Old 01-20-2019, 08:48 PM
ZombieF150's Avatar
ZombieF150
ZombieF150 is offline
ZombieF150 is starting off with a positive reputation.
Where you put the key in.
Old 01-20-2019, 09:06 PM
My4Fordtrucks
That is not correct. You put the key in the lock cylinder. The ignition switch is on the column.
Old 01-20-2019, 09:14 PM
ZombieF150's Avatar
ZombieF150
true. I have been corrected.
Old 01-21-2019, 10:51 AM
marksman76
marksman76 is offline
marksman76 is starting off with a positive reputation.
Automatic or manual trans?
if manual, Check clutch safety switch on clutch rod. See other posts to bypass this safety switch. Note key word "safety"
If automatic check neutral safety switch. Check for corrosion on all cables from battery , to solenoid, to starter.
Old 01-21-2019, 06:20 PM
Follmerpa
Update...
Crap i unsubscribed to this post by accident so i did not see last post.
I replaced ignition switch it did not solve my problem of not starting. Truck starts at starter relay but when i turn key???
Old 01-22-2019, 10:15 AM
My4Fordtrucks
Are you testing anything or just throwing parts at it?
Old 01-22-2019, 11:51 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is online now
'89F2urd has a very good reputation on FTE.'89F2urd has a very good reputation on FTE.'89F2urd has a very good reputation on FTE.
I would just keep replacing the starter until it starts.
Old 01-22-2019, 04:28 PM
Follmerpa
WOW real funny *******
Old 01-22-2019, 04:37 PM
Follmerpa
dont have anything to test with. So im spitting in the wind with this ..this all started after i put in new plugs and wires cap and rotor. It definitely needed a starter so that other jerk can **** off. The starter relay was really coroded i cleaned it up put still didnt work so i replaced it ..the ignition switch was mentioned in a reply above. I get my parts at oreily theres a guy there who is a ford guy. Hes telling me could be the tumbler or something in the steering column. Im in between jobs right now work construction so i really dont want to take it in if i can do it myself. So i spend time on this forum and others to try and trouble shoot
Old 01-22-2019, 05:54 PM
'89F2urd's Avatar
'89F2urd
I wasn't being a jerk, just funny
Old 01-22-2019, 06:13 PM
joey2fords's Avatar
joey2fords
joey2fords is offline
joey2fords is gaining momentum as a positive member of FTE.joey2fords is gaining momentum as a positive member of FTE.
i'm sure no offense was intended, and you gotta admit, it WAS funny.
back to business ... without a multimeter (they are cheap, WAY cheaper than a starter), you can't provide us with any pertinent info and we are all spinning our wheels ... so to speak.
Old 01-22-2019, 10:11 PM
ZombieF150's Avatar
ZombieF150
Do any of the indicator lights come on when you turn the key? like the warning lights do normally before you hit the start position? everything power up like blower motor and stuff when the key is in the run position? No blown fuses?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
