48-52 door window channel
Jun 21, 2020 | 10:37 AM
Getting ready to install the passenger door glass and parts. Question on the glass channel, do the tabs go to the back near the door skin or towards the front near the access panel?
JB
Jun 21, 2020 | 10:47 AM
The side that's up in your pic goes towards the access panel.
Jun 21, 2020 | 12:46 PM
Roger that, so on the drivers side it should look like this correct Ross?
JB
Jun 21, 2020 | 12:51 PM
Jun 28, 2020 | 06:35 AM
I might be a little late on this but I think a felt washer goes behind.Am I correct on this guys?
Jun 28, 2020 | 08:12 AM
Quote:
Originally Posted by
leonharu
Yes, to eliminate rattles there. Question I had was do you grease the felt washer or put it in dry? Manual is silent on that.
JB
Jun 28, 2020 | 08:47 AM
3twinridges
JB
JB,I could not even find a felt washer that would work!I made some thin rubber ones and lubed everything thing on my regulator and put a thin film of grease on the regulator “teeth”
Jun 28, 2020 | 03:36 PM
I think mine has wave-washers, thin ones that keep tension on the clips. If I had felts I would oil them.
Feb 11, 2022 | 10:57 AM
ALBUQ F-1
My cab should be painted soon and will be installing glass. I was wondering what size those hairpin clips are?
Feb 11, 2022 | 11:39 AM
Not sure on the size as I reused my old ones. Did see that Mid Fifty sells similar ones. $3.85 for the set of 4.
Feb 11, 2022 | 03:33 PM
Teflon washers are available in a multitude of sizes and thicknesses...one might work well in this application.
Feb 16, 2022 | 01:30 PM
51fred
i found the old ones in a box from the previous owner. On a side note i made my own washers out of jute padding.
Jul 13, 2022 | 02:57 PM
GB SISSON
1947 and Older Ford Trucks
Jan 29, 2017 02:58 PM
AeroZona
Aerostar
Sep 17, 2013 02:25 PM
FORD4STE
Apr 22, 2013 01:51 PM
stil190
Aug 8, 2010 05:06 PM
marlin_road
Aerostar
Oct 2, 2005 12:20 PM
