I'm upgrading to some fullforce 205/80 sticks and installing Riff Raff stainless cups and figured EH why not do the radiator also. it seems that everywhere I look the only thing I can find is Mishimoto as an upgrade. Was hoping that someone out there can give me some different options. I'm looking for an all aluminum with aluminum tanks that is better than a stocker.
bit skeptical about an ebay radiator. I don't mind spending money for a nice radiator, just seeing if there is anything other than mishimoto
I have been running one in my F350 and one in the wife's Excursion for about 9-10 years with no problems...even converted both to the HD ELC red coolant...
it seems that I should reconsider the ebay radiator. thank you for the info sir.
You might also consider replacing the hoses while you are in there...and if you do get the upper hose for a dual alternator setup that will go around the serpentine belt so you don't have to remove the hose to change out the belt. It will fit in that spot below the alternator made into the bracket...hard to explain, but you will see what I'm talking about...and I just zip tied it in place to hold it there.
Don't discount the value of the fleabay marketplace, it's where I get a lot of stuff, just be prudent in what you buy and from whom. Almost anything you could want is for sale there.
