3 row vs 4 Row Radiator
Old May 23, 2019 | 12:46 PM
Adam Woolridge's Avatar
Adam Woolridge
My cheap autozone radiator has sprung a leak at the top tank after two years and I am going to replace it with a Champion aluminum radiator. They have two options, 3 or 4 row at only a $50 difference. Is upgrading to a 4 row worth the extra money? My truck is a stock 351M/C6 and does do some occasional towing, but nothing crazy.
Old May 23, 2019 | 12:56 PM
beartracks's Avatar
beartracks
Aluminum radiators typically have fewer rows that brass. Most of the ones I see are only two rows. that cools a lot better than 4 row brass.
Old May 23, 2019 | 01:01 PM
Adam Woolridge
I don't have a lot of experience with selecting radiators (been lucky so far). Are fewer rows better at cooling in aluminum? I've done a lot of searching on here and found too much information on the radiator topic. A lot of conflicting opinions and information.
Old May 23, 2019 | 01:08 PM
ranger140892's Avatar
ranger140892
Grumpy goat
I bought a Champion 4 row to replace my factory 2 row, and love it. I didn't even consider buying the 3 row
Old May 23, 2019 | 01:13 PM
Adam Woolridge
I'm leaning toward this route as well. It's only $50 more. Did it run noticeably cooler after you swapped?
Old May 24, 2019 | 06:50 AM
ranger140892
Grumpy goat
It didn't drop the mean coolant temp, but it did stabilize it. No more temp spikes on really hot days, after hard acceleration, or when pulling heavy loads. I'm running a 192 deg thermostat, and that's where it stays.
Old May 24, 2019 | 07:02 AM
Adam Woolridge
Thanks...that's exactly what I was looking for. With this cheap, leaky radiator, my temps will spike the same way on hot days. I didn't want to put something similar back in.
Old May 24, 2019 | 07:34 AM
Adam Woolridge
Ok, quick tech support question here...I may be overthinking this, but do I need the engine side mount or the grille side mount??
Old May 24, 2019 | 07:56 AM
ss27gogeta's Avatar
ss27gogeta
I recently replaced my radiator in my 78 after it over heated at a drive-drive through. I got a 3 row champion and its grate its not over heated or got hot since. truck runs better to also you might have to cut some of your core support to get one in. the one I got was wider than my old one. I had to cut the core support to the next mounting holes.
Old May 24, 2019 | 09:04 AM
ranger140892
Grumpy goat
Mine is engine side mount...Radiator is on engine side of core support, mounting bolts go in from engine side. My truck is a 79 F150, 4wd, originally 351M, now 400. I did not have to cut the core support or modify anything.
Old May 24, 2019 | 09:09 AM
beartracks's Avatar
beartracks
I used a two row Be Cool unit. Larger one available for 1977. Way more than adequate for 435 hp, auto, air hauling etc. With a double electric fan.
https://becool.com/pages/aluminum-radiators
Old May 24, 2019 | 11:41 AM
Halfabrickshy's Avatar
Halfabrickshy
FWIW, my '79 F-350 Trailer Special which was designed for towing came with a 3 row from the Ford engineers. I've had 4000 pounds of rock in this thing and it didn't overheat, just took longer to stop. More rows mean more passes before it returns to the engine, but those passages are smaller to fit into the same physical space. Conversely, fewer rows equal fewer passes, but bigger passages. Both work, but it's sort of a Miller/Lincoln, Ford/Chevy thing, everybody's got their favorite. 3 row works for me, YMMV.
John
Old May 25, 2019 | 09:31 AM
ranger140892
Grumpy goat
John
Negative. Compare measurements of Champion 2 Row vs 3 Row vs 4 Row. The 4 row is 1" thicker than 2 row, and 1/4" more than 3 row. It holds more coolant.
Old May 25, 2019 | 10:33 AM
beartracks's Avatar
beartracks
Aluminum radiators are stronger. This allows for larger tube size, larger flow per tube. Number of tubes has nothing to do with number of passes. just one.
see the Be Cool link
Old May 25, 2019 | 05:36 PM
Halfabrickshy
Yeah, I was just going from memory which apparently isn't too good. Mine turned out to be rebuildable so I didn't look in-depth. Checked out the Be Cool site, nice stuff.
