Harmonic balancer help?
Old Jun 18, 2020 | 04:56 PM
Hyperhad's Avatar
Hyperhad
Hello, I am looking for a 1996 F250 heavy duty harmonic balancer with the four prong pulse ring attached to make it California compliant.
Do any of you guys know where I could buy one at or can I use the one I bought that is ok for 49 states and somehow bypass my check engine light that keeps coming on with this?
The check engine light is because of the crankshaft position sensor not reading the harmonic balancer due to there being no pulse ring.
I do know that there's the DamperDudes website but every time I call no one picks up the phone.
Here is the link for what I need I just am wondering if there's any other company who sells it or can it just be as simple as calling my local Ford part department?
https://www.damperdudes.net/harmonic...1-up-e1te-c3a/
Thanks in advance.
Old Jun 18, 2020 | 07:02 PM
mrollings53's Avatar
mrollings53
Try emailing them, or filling out the contact form on the website. There may be no one to answer the phone due to Covid lockdowns.
Old Jun 20, 2020 | 07:41 PM
cougrrcj's Avatar
cougrrcj
The four prong star harmonic balancer is no longer available for 5.8s (many more Mass air F-150s made), and probably not available for 7.5s (not as many Mass-air F250/350s). The crank position sensor is only there to pick up the signal for the misfire monitor on OBD2. With the right scan tool/programmer, I believe you can disable that function. My buddy did a OBD2/Mass air conversion of his 5.8 and ran in to that issue - his solution was to have a four-prong star made that bolts to the readily available Federal balancer.
Old Jun 21, 2020 | 06:17 PM
torq'ta 5 8's Avatar
torq'ta 5 8
his is OBD I, so he cant program that out, would you have to clock it, would he also need to know how far apart each point needs to be, or just 4 quarters.
Old Jun 21, 2020 | 06:49 PM
cougrrcj's Avatar
cougrrcj
'96 CA-emissions would be OBD2, hence the star balancer.
Old Jun 25, 2020 | 04:24 PM
Hyperhad's Avatar
Hyperhad
This is just so retarted because I've been looking for this pulse ring everywhere I guess I can either make one or go looking for one at a local junkyard. If I make one, is there any official schematics? If so, does anyone have them?
Old Jun 25, 2020 | 04:25 PM
Hyperhad's Avatar
Hyperhad
courgrrcj what scan tool can I use to bypass that because I do have an average code reader but it keeps throwing a code for that pulse ring?
Old Jun 27, 2020 | 01:10 PM
cougrrcj's Avatar
cougrrcj
If you still have your original, you can have it rebuilt. As for the bolt-on star - my buddy drew it up and had it machined locally, it is on the new 393W that is going into his truck to replace the old 200k-mile 5.8L, so for now he has to stare at the Engine light on the dash... still runs fine, but the computer is looking for the misfire monitor signal...He wants to retain the misfire monitor for the 393W so he hasn't 'bypassed it'
I'm not sure which scan tool my buddy has - only that it was a couple grand, and some vehicles/features are on a paid subscription basis... ASE Master electronics and emissions certification tech. He's always getting calls to diagnose weird stuff that 'normal' (low-buck) shops can't figure out.
Old Jun 28, 2020 | 06:29 AM
torq'ta 5 8
DamperDoctor.com, rebuilds them, if you happen to have your old one
Hyperhad
Jun 4, 2020 07:55 PM
Luv2Cruise
Feb 1, 2019 05:20 PM
92lx
Jun 19, 2006 02:59 PM
nikwave
Jan 6, 2005 10:58 PM
