How does one remove the alternator pigtail?
Old Jun 26, 2020 | 07:59 PM
Air Cooled Nut's Avatar
Air Cooled Nut
Question How does one remove the alternator pigtail?
1990 F-250 7.5L, shorted alternator is draining battery and is very, very warm. I need to remove the 3-wire plug that goes into the side of the alternator as that is the positive power feed to the battery. It's a tight fit in there and the plug is deep in the alternator body so it's not obvious to me how to get it out while the alternator is still mounted to the engine.
Truck is going in to the shop for a new unit sometime next week I hope.
Old Jun 26, 2020 | 08:17 PM
Air Cooled Nut
Never mind, I got it.
The plastic spring clips on the pigtail need to be lifted in order to be unlocked, much like the 2-wire plug on top of the alternator that's very easy to remove. Getting in there to lift the top and bottom clips isn't possible so I used a 2" flat-bladed screwdriver and pried the plug out from the sides. The plug spring clips didn't seem to be on tightly so that made it easier to shimmy the plug out.
Now the battery is taking a charge and hopefully once it's topped off it'll be enough to get me to the shop a few miles down the road...
Old Jun 27, 2020 | 01:59 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Ideally you aren’t supposed to use the alternator to charge the battery. You should put it on a battery charger.
Old Jun 27, 2020 | 09:05 PM
BLK79's Avatar
BLK79
I would get rid of the 2G and swap alternator and harness to 3G. Got mine out of a 96 460 truck in JY. Harness from alt to fender solenoid, I had to break out one wire (green with red/pink stripe if I remember correctly - been a few years). I did it mostly to eliminate fire hazard associated with 2G plug.
Old Jun 27, 2020 | 11:44 PM
Bubba Jones's Avatar
Bubba Jones
Yeah that's a good idea for sure. I read over this post before realizing I did just that on the 88 I'm restoring without even thinking about it! The alternator wiring harness is super easy to swap out, you just need to cut and splice that green wire (that's on it's own pigtail making it very easy) and then unbolt the old harness from the fender relay and bolt the new one in.
I'm sure you could make one relatively easy as well, but if the junk yards aren't too far out of the way, these trucks are ridiculously common so finding a harness shouldn't be a problem. It probably would be cheaper getting the harness from the junkyard than trying to build it as well.
Old Jun 28, 2020 | 09:47 AM
Air Cooled Nut
Correct, the alternator does charge the battery...when it's working. When I said "Now the battery is taking a charge and..." I meant it was on a battery charger and the battery alone will get me to the shop where the alternator can be correctly replaced.
Old Jun 28, 2020 | 09:49 AM
Air Cooled Nut
Thanks for the tip on the 2G to 3G conversion, I appreciate it!
Tooler2
2009 - 2014 F150
Jul 27, 2019 10:01 AM
Brad Borchers
Nov 26, 2015 09:50 AM
muddiejeep
Sep 26, 2008 08:36 PM
tbenton
Mar 10, 2004 10:12 AM
