New harmonic balancer throwing up check engine light
Old May 15, 2020 | 06:33 PM
Hyperhad's Avatar
Hyperhad
Hello.
I have a 1997 F250 Heavy Duty truck but it is an OBS.
My old harmonic balancer was bad and when I changed it I noticed a check engine light on.
I also noticed that my old balancer had this sort of 4-pronged flange attached to it and I'm 100% sure that is what's causing my check engine light.
The thing I do not get is the new balancer I bought fits but I am thinking I didn't press it in all the way. The only difference between my new and old balancers is the 4 prong flange shown below. Is there a different harmonic balancer that I have to buy or is there a way I can take that flange off and put it only new one.
Below is my old balancer:
Old May 15, 2020 | 06:40 PM
timbersteel's Avatar
timbersteel
Missing the 4 way cross is setting a CEL. It shouldn't affect performance.
This has been noted in the past on FTE. It has been addressed several times in the last 6-8 months.
Others may chime in with the actual part name.
Old May 15, 2020 | 06:44 PM
cougrrcj's Avatar
cougrrcj
CA emissions = that four prong star is needed for the crank position sensor / misfire monitor (sensor is attached to your timing cover) on EEC-V / OBD2 equipped engines.
Old May 16, 2020 | 10:24 PM
GoinBoarding's Avatar
GoinBoarding
I had the same issue on my 1996 f150 with 5.8L. Nothing to worry about in terms of driveability but that code will remain active until remedied. No idea where to find a correct replacement part, unfortunately.
Old May 17, 2020 | 02:42 PM
cougrrcj's Avatar
cougrrcj
My buddy just did a SEFI EEC-V swap to his '95 5.8 F250 4x4 using a '96 Bronco engine/front body harness, along with the Bronco computer. Ran in to the same issue. He had an add-on 'tone ring' made at a local machine shop to bolt to the Federal emissions damper so the misfire monitor is happy... It CAN be done!
Old May 18, 2020 | 11:07 AM
wrongway01's Avatar
wrongway01
I just went through this on my 96 F-150 with a 5.8. Press the star wheel off of the old balancer and press it on the new balancer. Only inconvenience is that you will have to remove the new balancer first. I like to have drove myself crazy with that random misfire code until I figured it out.
Old May 18, 2020 | 05:46 PM
cougrrcj's Avatar
cougrrcj
OR - there's a place my buddy told me about that will rebuild your balancer - remove the outer ring, re-vulcanize new rubber, re-balance for ~$110 WITH the un-obtainium star in the proper place to make misfire monitor happy, too!
Old Jun 4, 2020 | 03:39 PM
Hyperhad's Avatar
Hyperhad
Is there any way that I can buy another one with that star flange on it? Or where I can get it?(I threw away the old one foolishly at the dump)
Old Jun 4, 2020 | 05:18 PM
Festus2's Avatar
Festus2
These people may be able to help.
https://www.damperdoctor.com/
Old Jun 4, 2020 | 07:55 PM
torq'ta 5 8's Avatar
torq'ta 5 8
JY in Cali would be a place to check for it, your's 302, or 351w
Big Silver One
May 31, 2019 09:18 PM
ugh3012
Modular V8 (4.6L, 5.4L)
May 22, 2016 06:40 PM
nikwave
Jan 6, 2005 10:58 PM
