Stuck Inner Race
Old Jun 17, 2020 | 03:09 PM
dustinnicholson215's Avatar
dustinnicholson215
Stuck Inner Race
Good afternoon, everyone. I have a 1992 F150 4x4 with autolocking hubs. A while back, while driving at about 80 mph on the interstate, my front driver side wheel bearing went out. I towed it home, and removed the hub as well as the locking nuts to prepare to pull everything off of the spindle to replace the bearings. Unfortunately the inner race was stuck on the spindle making it impossible to pull the rotor/hub tube off. With the way the design is, I was unable to fit a puller inside the tube to pull the race. I’ve tried to loosen it with a punch and a mallet as well as smacking the inside of the rotor (yes I’m going to replace it anyways while I’m in there), but with no success. I can’t get a torch inside the tube to apply heat with any sort of accuracy. I was wondering if any of you more mechanically inclined individuals might have some suggestions. Thanks in advance for your time.
Old Jun 17, 2020 | 08:37 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Not impossible. Just more difficult. Grab the rotor and pull to overcome the friction holding the grease seal in the hub. Once you have the rotor off you can very carefully use a Dremel or cutoff wheel to cut the bearing off the spindle.
86Hicks
16
Feb 23, 2020 06:16 PM
davehaynes
Aug 2, 2011 03:43 PM
ErrorS
1978 - 1996 Big Bronco
Sep 28, 2010 06:39 PM
tseftons
Sep 13, 2010 08:54 PM
gilllawn
13
Jan 27, 2010 02:08 PM
