stuck hub
Old Aug 1, 2011 | 10:08 PM
davehaynes's Avatar
davehaynes
stuck hub
anyone have a secret to getting a stuck hub (rotor) off ,have some bearings that fell out and cant seem to wiggle the hub off,
thanks
Dave
Old Aug 2, 2011 | 05:21 AM
Franklin2's Avatar
Franklin2
The complete assembly (hub/rotor) has to come off and then the studs have to be driven out. Then the rotor will separate from the hub.
Old Aug 2, 2011 | 09:01 AM
davehaynes's Avatar
davehaynes
thats the problem i cant get the whole unit off the wheel beerings came apart ,im not trying to get the two units seperated just the whole unit so i can replace the wheel beerings but there is probably the dust shield and bearings jammed in there and i cant get the darn thing to slide off.
Old Aug 2, 2011 | 02:26 PM
Franklin2's Avatar
Franklin2
If the wheel bearings had a catastrophic failure, the inner race probably spun on the spindle and welded itself to the spindle. If the outer bearing is stuck on the spindle, you have a big problem. It it's the inner bearing, just keep jerking on it till you get the bearing to slide the wheel seal out. Then you can work on getting the inner bearing off.
Old Aug 2, 2011 | 03:43 PM
dohc_chump's Avatar
dohc_chump
This space for rent...
Dave, grab yourself a rubber mallet. Crank the steering wheel whatever way provides you access to the space between the caliper bracket. Whack the rotor, spin it, whack, spin, whack, spin... you get the idea. You MIGHT be able to get it to walk off. If the outer bearing is welded on, time to find a JY knuckle with a good spindle.
lowbed dud
Oct 1, 2012 06:19 PM
law2212
Dec 7, 2011 04:25 PM
ErrorS
1978 - 1996 Big Bronco
Sep 28, 2010 06:39 PM
tseftons
Sep 13, 2010 08:54 PM
WesDaBest
Mar 31, 2008 11:40 AM
