Sponsored by: Real Truck
steering wheeel upside down
Old Jun 6, 2020 | 11:48 AM
eckart's Avatar
eckart
I just put an adjustable trac bar in to recenter my axle. iv just go a leveling kit. i put 12.5x35s on the truck and they rub the passenger spring so that solved that but as im trying to center my steering wheel I've discovered its upside down when my pitman arm is pointed straight forward and the box is in the middle of it stroke. turn and a half each way. so how do I fix that? thnaks for any help
Old Jun 6, 2020 | 02:38 PM
seville009's Avatar
seville009
https://www.ford-trucks.com/forums/3...ing-wheel.html
Old Jun 7, 2020 | 11:52 AM
Lance Kohler's Avatar
Lance Kohler
drag link
search “drag link bar adjustment“ on youtube
Old Jun 7, 2020 | 12:17 PM
crusty old shellback's Avatar
Sounds like you didnt have the steering wheel right side up and the box centered when you reconnected everything.
did you disconnect the box from the steering shaft during the install? If so, that's where it hapoened.
Adjusting the drag link wont fix it.
Old Jun 7, 2020 | 03:30 PM
SuperDutyScaler's Avatar
SuperDutyScaler
The leveling kit lifted the front end, in return the drag link is now too short so it pulled the pitman arm, turning the steering wheel. Simply loosen the adjuster sleeve on the drag link and recenter the steering wheel
Old Jun 7, 2020 | 05:09 PM
He said his steering is in the middle of the throw. Are the tires pointed forward at that time? If so, adjusting the drag link will not fix it.
Old Jun 7, 2020 | 05:33 PM
SuperDutyScaler
No he wrote steering back is in the middle of the throw, 1.5 turns in each direction. THE problem is the steering wheel is upside down
Old Jun 7, 2020 | 05:41 PM
Correct. So if you adjust the drag link to righten the the steering wheel, it will no longer be on the middle of the throw.
I dont think hes telling us everything we need to know. It sounds like he disconnected the steering gear box from the steering column and it was upside down when he reconnected.
adjusting the drag link is to center the wheels and steering wheel that last little bit, not a half a steering wheel turn. That's a lot.
and if you did turn it enough to move that far, the gear box would no longer be centered.
They all play a part.
DanielT28
Sep 2, 2014 09:48 AM
tcjhkbjt
Dec 4, 2013 01:51 PM
77-250
Apr 16, 2008 02:33 PM
Brats
May 29, 2007 06:10 PM
fcfirefighter05
Apr 15, 2006 01:20 PM
