steering wheel adjustment
Old Dec 4, 2013 | 11:57 AM
tcjhkbjt's Avatar
tcjhkbjt
I just recently installed a lift on my truck and noticed that my steering wheel is not straight anymore. In the instructions it says that I need to entend the drag ling, aka steeering arm, but doesnt show a picture of this. I kinda have an idea where it is but 100% sure. Does anyone have a picture that shows where I need to make the adjustments?
Old Dec 4, 2013 | 01:05 PM
BLADE35's Avatar
BLADE35
Its the part that Comes off the steering gear box
Didn't your kit have a longer pitman arm for the lift???
Old Dec 4, 2013 | 01:14 PM
Ian123's Avatar
Ian123
There should be two bars that come from the frame-area of the truck and connect down at passenger side of the axle. One is the track bar, which is not adjustable, and the other is the drag link which you will need to extend. There are two bolts on it that you loosen and then you turn the threaded piece to extend it. It will probably be pretty seized up and hard to turn (mainly because its so hard to get a grip on). My friend and I messed with it for about an hour and barely got it to move, we gave up and took it to an alignment shop. Maybe you will have better luck than we did.
Old Dec 4, 2013 | 01:15 PM
Ian123's Avatar
Ian123
Benny the smaller lifts usually don't come with a drop pitman arm. 6" and up always has them, 4" it depends on the kit.
Old Dec 4, 2013 | 01:23 PM
BLADE35's Avatar
BLADE35
Yes sir
I just saw your post and realized he needs to adjust the Drag link for some reason I had it in my mind he wanted to know what was the pitman arm
Maybe he can try to use a Pipe wrench to adjust it they usually are seized good
That drag link is the one Coming from the Pitman arm to the Passenger side Steering knuckle area that's for 03 anyways
All you have to do is adjust it (Spread it) until the steering wheel is Centered driving down the road
GregsSD's Avatar
GregsSD
You need to adjust the upper "Adjusting Sleeve" in this pic:
Old Dec 4, 2013 | 01:47 PM
tcjhkbjt's Avatar
tcjhkbjt
thanks guys for the help, i think i got it figured out now. FYI I have a 4" lift but the kit cant with spacers that i installed under the pitman arm.
Old Dec 4, 2013 | 01:51 PM
tcjhkbjt's Avatar
tcjhkbjt
thanks guys, I think I got it figured out now. FYI I have a 4" lift but the kit came with spacers to put under the pitman arm. Thanks GregsSD for the pic.
timlange
28
Jun 13, 2019 04:52 PM
playsinmud
Jun 3, 2007 03:10 PM
415C.I. Guy
Apr 6, 2005 09:37 AM
250SDBeast
Jan 2, 2004 10:44 AM
offroadjunkiex
Jul 27, 2003 06:40 AM
