Tailgate Opening Randomly
Old Jun 5, 2020 | 08:52 AM
Backnblack's Avatar
Backnblack
If it keeps opening on its own, I'll be adding a relay to an upfitter switch to control the power to that damn thing.
Old Jun 5, 2020 | 09:11 AM
bittondb's Avatar
bittondb
Hmm. Never thought of that. However, if the switch is off, do you still have power to the tailgate so the button under the handle?
Old Jun 5, 2020 | 09:33 AM
Backnblack's Avatar
Backnblack
I doubt it. Wouldn't bother me too much.
Old Jun 5, 2020 | 09:37 AM
VoodooRob's Avatar
VoodooRob
I had the recall done recently for the tailgate harness. I started the thread "phantom tailgate" in 2017 about gobbing dielectric grease in the 2 plugs by the spare tire. Once I did that "fix" in 2017 I never experienced "phantom tailgate drop" ever again. So I get the recall notice for the harness and figure since I had a few other recalls, get it done while it's there. I drove the truck in heavy rain last week and parked it in the garage, I checked tailgate operational as it should so all is good. BUT, the next day I go to fire the truck up, within 5 seconds of start up I get flashing "must be in park" then the truck would completely shut off, no lights on dash, seat would retract wheel would go up. Tried to start a couple times, same results. I thought lets hit the tailgate, turn ignition and nothing worked. I crawl under the truck, the new harness assembly has 4 small plugs vs the old 2 larger plugs. Pop the plugs apart and 3 of the 4 are full of water! I dry them out with air gob the dielectric grease on both sides of all the plugs, and everything now works. Guess the recall fix is not worth it to have done. Stick with gobbing all the plugs and go on with your life, Ford is not fixing the problem.
Old Jun 5, 2020 | 09:57 AM
Backnblack's Avatar
Backnblack
Thanks for that info VoodooRob....
Old Jun 6, 2020 | 08:05 AM
03griz's Avatar
03griz
Originally Posted by Absoluteblack2018
Make sure you hit unlock first, otherwise it won't drop.
That was it exactly. Thank you.
Old Jun 6, 2020 | 06:13 PM
Absoluteblack2018's Avatar
Absoluteblack2018
No problem! I know I did the exact same thing a couple weeks ago and after a few minutes of “ARE YOU KIDDING ME PROBLEMS ALREADY!” I figured it out lol.
Old Jun 10, 2020 | 11:29 PM
C-Andrade's Avatar
C-Andrade
Same issue with my 18, I'll be checking the harness on mine!
Old Jul 10, 2020 | 08:15 PM
Smoking Joe's Avatar
Smoking Joe
Where is the new harness connectors. I need to do this.
Old Jul 10, 2020 | 11:06 PM
VoodooRob's Avatar
VoodooRob
Where the hitch bolts to the frame, drivers side
Texaswilliam
Mar 1, 2020 08:19 AM
Aftrmidnite
General Automotive Discussion
Feb 17, 2020 05:04 AM
hobbie1
Feb 12, 2020 10:40 PM
Newfordtome
Dec 17, 2018 07:58 PM
