Does changing rear gears effect Front diff?
Old May 29, 2020 | 03:20 PM
Drothgeb's Avatar
Drothgeb
Originally Posted by harmanrk
Probably not the reason, as when you look at the parts involved, the rear drive shaft is much stouter than a lot of the front end parts. The weakest part will fail first, and my guess is the transfer case, or the front drive shaft.
It broke where the tube was welded to the rear yoke, hardly any penetration on the yoke. So a crappy factory weld was the weakest point.
Actually, it was kind of exciting. I was probably 18-19, and had an LT1 in my old K5 Blazer. Big group of us were at the local gravel pit doing hill climbs. I was close to the top of the biggest hill with my foot to the floor and KAPOW!!! Loud banging and sparks flying.... everybody was cheering.
Old May 29, 2020 | 03:30 PM
Pugga's Avatar
Pugga
Originally Posted by Spaceman_Spiff
I was reading through some threads where people changed thier rear gears but never mentioned replacing them in the front.
Were these 2wd trucks by any chance?
Old May 29, 2020 | 05:12 PM
Spaceman_Spiff's Avatar
Spaceman_Spiff
I honestly don't remember. There are quite a few threads out there and i searched other makes too. I'm sure some were 4x4, but knowing my luck.
Old May 29, 2020 | 05:37 PM
Desert Don's Avatar
Desert Don
What i'm asking is if i change my rear 3.55 gears to say something like 4.30's, and i engage 4wd, will it effect the driveline in a negative way? Because the front stay at 3.55.
Seriously???? I might have to put some thought into this before I even think about it!!
Rear axle going to turn 1 revolution per 4.3 revolutions of the drive shaft.....front axle going to turn 1 rev per 3.55 rev’s of the DS.
How do you even think this might work out?
Old May 29, 2020 | 07:12 PM
Texas78028's Avatar
Texas78028
In the late 80's I had a 65 Chevy stepside that had 3:07 front and 3:73 rear ratios. I only used 4x4 in very muddy or slippery conditions. It would pop like crazy once I had good traction. I would actually have to back up slightly to get the NP205 xfer case unlocked. I would recommend against this idea unless you plan to drop the front driveshaft and leave it as a 2wd … and I don't recommend that either. Good luck.
Old May 29, 2020 | 07:21 PM
Spaceman_Spiff
lol, you mad about something? I didn't think it would thats why I asked. Thats what these fourms are for. You don't have to read it if it upsets you so much. Lol. Wow.
Old May 29, 2020 | 07:25 PM
Desert Don's Avatar
Desert Don
Mad?????? LOL.
Just trying to help you visualize how bad an idea this might be.
Old May 29, 2020 | 07:32 PM
Spaceman_Spiff
Mad?????? LOL.
I get it. People have already answered.
Old May 30, 2020 | 08:28 AM
Spaceman_Spiff
Here's one of the more recent threads I read. I don't see anything about the front diff.
https://www.ford-trucks.com/forums/1...ear-end-2.html
and it looks like his is a FX4. He may have ordered 2 sets. I could have missed it or misunderstood.
Old May 30, 2020 | 08:58 AM
HRTKD's Avatar
HRTKD
I've seen on other forums where guys have changed just the rear differential on a 4x4 vehicle. They acknowledge that they won't use 4x4. Engaging 4x4 would be like playing Russian Roulette. My worry would be that someone unfamiliar with the modification would drive the truck. Like some 18 year old "technician" at the dealership that likes to play with all the switches in a truck.
Old May 30, 2020 | 09:01 AM
Desert Don's Avatar
Desert Don
Well, we will *** U ME that, since the post was about finding gears for the relatively new DANA M275, that he was also getting gears for the Front D60(which has been around like forever) and therefore no problem finding gear sets for.
Otherwise, with 1000 RWHP, he will either never use 4WD or things are going to go to hell in a hurry for him
Old May 30, 2020 | 09:23 AM
jimd1050's Avatar
jimd1050
BuhBye F450, I'm relaxin'
If, in fact, you go back to the OP, he states that:
4.30 gears in a Dana M275 rear end
I'm looking at switching gears in my 2017 f350 with the m275 rear end. It has 3.55's and looking to switch out to 4.10's or 4.30's. Has anyone done this or has any info on where to get the parts from? I'm looking at switching both the rear and front gears. I've called a few places and no luck so far.
So, you're correct and NOT "*** U ME"ing Don! (I know there's no "e" in assuming but had to leave it there)
Old May 30, 2020 | 09:55 AM
  #28
Spaceman_Spiff
Sure does.
black_truck
1997 - 2003 F150
Aug 17, 2004 06:02 PM
kameronth
1978 - 1996 Big Bronco
27
Apr 19, 2004 02:03 AM
taylordaddy5
Sep 11, 2003 07:29 AM
CPerry
1997 - 2003 F150
Jul 9, 2003 08:43 AM
Steve86
Jul 2, 2003 09:34 PM
