Changing rear differential
Old Sep 10, 2003 | 07:31 AM
taylordaddy5's Avatar
taylordaddy5
Current F250 4WD 460 w/ 4.11 gears.
Is is possible to change to a 3.55? Would
this require any changes to front axle and/or
differential?
Old Sep 10, 2003 | 09:28 AM
ecarter50's Avatar
ecarter50
Yes you can change to 3.55. If you want to use 4wd you will have to change the front gears to match.
Old Sep 10, 2003 | 08:59 PM
fishmanndotcom's Avatar
fishmanndotcom
I'll take the 4.11's off your hands if you are gonna get rid of 'em...I need an extra set bad...I don't care how worn they are.
-Jason-
Old Sep 11, 2003 | 07:29 AM
taylordaddy5
Thanks for the information.
Jason - If I can find the gears for the front and rear, I will let you know. Thxs! Michael
