Sponsored by: Auxito
Changing gears
Old Jul 8, 2003 | 01:29 PM
CPerry's Avatar
CPerry
Changing gears
I'd like to replace the 3.55 gears on my truck with 3.73 because of larger tires. Do I need to replace the front (4X4) also or can I get by with only changing the rear?
Old Jul 8, 2003 | 03:34 PM
JeremyH's Avatar
JeremyH
Changing gears
You can drive it on the street when you are not in 4wd since your front driveshaft is not engaged, but it will not work when in 4wd. Change them both.
Old Jul 8, 2003 | 06:04 PM
LxMan1's Avatar
LxMan1
Changing gears
yes, change them both or when you put it in 4x4, it will definately tear up something!!!
Old Jul 8, 2003 | 09:43 PM
Ultramagdan's Avatar
Ultramagdan
Changing gears
Going from a 3.55 to a 3.73 will not provide a big difference. It was a couple of years ago or so that a similiar thread was developed. The upshot was that it takes a bigger swap in gears to get a change. Like a 3.55 to a 4.11. 3.31 to 3.73 would also be a good one. For that much expense, be sure that's what you want.
Old Jul 9, 2003 | 03:02 AM
CPerry's Avatar
CPerry
Changing gears
I was thinking about going from 265/75 to 305/70/16 tires so I'm not quite sure if I need 4.11 gears but I will do my research before I make a decision.
Old Jul 9, 2003 | 08:43 AM
kmeifert's Avatar
kmeifert
Changing gears
265/75 should be about 10.4" wide at their widest point. The sidewall should be 7.8 inches tall, resulting a total diameter on the rim of 31.6"
305/70 should be about 12" wide. The sidewall should be about 8.4 inches tall, resulting a total diameter on the rim of 32.8"
These are estimates based on the numbered sizes and will vary a little according to the manufacturers toloranes.
total circumferance on the 265/75 would be 99.22" while on the 305/70 it would be 102.99"
265/75 would rotate about 639 times per mile
305/70 would rotate about 615 times per mile
I would leave the 3.55 considering the substantial expense. I am not sure now the speedometer on these trucks is driven but it will probably read 4-5% slower than your actual speed after the tire change based on the calculations above.
