white smoke when warm
Old May 23, 2020 | 08:30 PM
gogereaver's Avatar
gogereaver
update after pulling my oil dipstick on oil i just changed and yep its grey. blown oil coller/head gasket. lets prey to god its not cavitation.
Old May 25, 2020 | 12:48 AM
genscripter's Avatar
genscripter
It depends on your block. Do you have a 7.3 or 6.9? if you have a 6.9, cavitation is unlikely. And even with the 7.3, cavitation is an overblown fear. It's likely your oil cooler or more likely your HG's.
Old May 25, 2020 | 07:40 PM
gogereaver's Avatar
gogereaver
i did overheat it so im just praying the heads are not cracked. i am ording a complete gasket set. valley pan oil coller head gasket valve cover and valve seals. make dam sure its done the first time.
Old May 25, 2020 | 08:01 PM
DarkOverCast's Avatar
DarkOverCast
Be sure to get those heads checked...
Old May 26, 2020 | 11:52 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I guess now you can Unstick those Glow plugs with less issues now.
wouldn't be a bad time to go thru the oil cooler at this point either.
Old May 26, 2020 | 02:29 PM
gogereaver's Avatar
gogereaver
yep now the heads have to come off.
Dean88
Oct 16, 2008 07:59 PM
boss429kiwi
Oct 24, 2007 07:51 PM
jmunkie13
Jan 30, 2007 09:52 AM
crack
Aug 30, 2006 07:43 AM
racin-nate
Dec 11, 2003 05:56 PM
