blue/white smoke
Old Dec 9, 2003 | 04:49 PM
racin-nate's Avatar
racin-nate
blue/white smoke
I have a 91 ford with a 6.9 ( got ripped off by the shop that was supposed to replace the 7.3 that was in it ).
It's been sitting for about 2 years, recently I got it running again, new lift pump, dropped and cleaned the tank, new filter, diffrent injection pump. Now when it runs at idle it has constant blue/gray smoke and when you are under throttle huge clouds of white/blue smoke. The motor did this the first time I saw it run after the shop installed it (rebuilt? my ***), they where supposed to change it, but never did. They did something to almost eliminate the smoke problem. It has excellent/even compression, but smokes like a bitch. It seems to have good power, but i've only taken it around the block. It also starts really well.
Cracking the line on each injector seems to cause it to miss.
Edit: Smoke increases are rpm increases, and the motor also starts to stumble at higher rpm. Throttle responce seems great.
Any ideas, advice?
Thanks
Old Dec 11, 2003 | 09:23 AM
Jens's Avatar
Jens
Hi
First welcome to FTE. Here are some information:
Blue or blue/white smoke:
Caused by insufficient fuel or oil consumption. Normal when engine is cold or idling for extended periods.
Excessive smoke could be caused by air in the fuel, contaminated fuel, loose or plugged injectors, thermostat stuck open, oil consumption, plugged crankcase depression regulator valve, retarded injection pump timing, or defective injection pump.
hope it will help
Jens
Old Dec 11, 2003 | 05:56 PM
racin-nate's Avatar
racin-nate
Jens, thank you for the welcome and your help.
The white smoke is gone, just the blue now. I'm going to try the pump timing. I will let you know.
Thanks,
Nathan
MrVerilog
New Member Introductions
Oct 29, 2014 06:05 AM
dieselsubmariner
Dec 15, 2013 09:35 PM
Xenthrax
31
Sep 23, 2013 07:45 AM
jr_vw2
Jul 9, 2012 04:45 PM
blaze42069
Sep 21, 2008 10:43 PM
