79 351w starter support brace
Thank You in advance for your help with this.
I have a 79 F350 with 351w and a c6 transmission. I do not have the support bracket that is in the back of the starter
that goes from Starter to engine block .
I think it’s supposed to have one
If someone would have a picture of it that would be great maybe I could make one. Or a part number be great too.
Thank You all
Leon
Thank You all
Leon
Ah I see we got a GM guy here.
Fords did not use a starter brace in most all automotive applications on the small blocks as they were not needed. The only things that got them were industrial and severe service applications.
GM used them cause their starter housings were much thinner castings and not nearly as strong as the Fords.
Also need right starter.
I also need to figure out what starter I need.
im told the engine is not the original one.
It has a C6 transmission is that what I need to go by.
i bought starter according to what it should have had and it won’t work.
unfortunately I don’t have the starter that was in it.
I appreciate Any and all help with this.
thank you
thank you
Relics
17
12-29-2009 10:26 PM
red85f250
07-12-2004 07:09 PM
