79 351w starter support brace
Old 05-21-2020, 06:03 PM
LeonL's Avatar
LeonL
LeonL is offline
Thank You in advance for your help with this.
I have a 79 F350 with 351w and a c6 transmission. I do not have the support bracket that is in the back of the starter
that goes from Starter to engine block .
I think it’s supposed to have one
If someone would have a picture of it that would be great maybe I could make one. Or a part number be great too.
Thank You all
Leon
Old 05-21-2020, 06:35 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
Welcome to FTE, lots of good people here.
Question, are you sure it's a 351W? Ford didn't put the 351W in this era truck. If it's factory it should be a 351M...two different engines.
Old 05-21-2020, 06:39 PM
LeonL's Avatar
LeonL
LeonL is offline
Yes it’s a Windsor
not a Modified or a Cleveland
possibly someone swapped it in the past
Old 05-21-2020, 06:47 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Originally Posted by LeonL
Yes it’s a Windsor
Looked in the truck parts catalog and don't see anything that looks like a support bracket. I'll check the passenger car catalog.
Old 05-21-2020, 06:54 PM
LeonL's Avatar
LeonL
LeonL is offline
It just seems like it should
there is even a tapped hole in the block in the right spot.
and there are only 2 bolts that hold it on
I could be wrong it wouldn’t be the first time.
thank you for you help
Old 05-21-2020, 06:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I checked the passenger car parts catalog too and don't see anything about support bracket for the starter.
I don't recall see one on a 351 or a 302 for that matter.
Old 05-21-2020, 10:36 PM
matthewq4b's Avatar
matthewq4b
matthewq4b is offline
Ah I see we got a GM guy here.
Fords did not use a starter brace in most all automotive applications on the small blocks as they were not needed. The only things that got them were industrial and severe service applications.
GM used them cause their starter housings were much thinner castings and not nearly as strong as the Fords.
Old 05-21-2020, 10:40 PM
LeonL's Avatar
LeonL
LeonL is offline
Not a GM guy anymore
Old 05-22-2020, 09:10 AM
CelticOne's Avatar
CelticOne
CelticOne is offline
Regular User
Welcome to the "Dentside"!
Old 05-22-2020, 09:25 AM
2dwoods's Avatar
2dwoods
2dwoods is offline
Never saw a brace before
Old 05-22-2020, 09:26 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
That's a GM thing just like starter shims.
Old 05-22-2020, 08:43 PM
F150 grabber's Avatar
F150 grabber
F150 grabber is offline
Just had this discussion with a buddy. He still swears g.m. Got it right.i have welded at least a dozen 4.3 blocks with starter holes broken out and not one ford or mopar.
Old 05-22-2020, 08:59 PM
LeonL's Avatar
LeonL
LeonL is offline
Also need right starter.
I also need to figure out what starter I need.
im told the engine is not the original one.
It has a C6 transmission is that what I need to go by.
i bought starter according to what it should have had and it won’t work.
unfortunately I don’t have the starter that was in it.
I appreciate Any and all help with this.
thank you
Old 05-22-2020, 10:18 PM
matthewq4b's Avatar
matthewq4b
Yup the standard and the autos use different starters. So the application is a 351W with an auto (C6)
Avoid off shore new ones and rebuilds of off shore units. Opt for a rebuild of a genuine Ford unit. The reason being some of the off shore castings have fitment/alignment issues.
Old 05-24-2020, 01:13 AM
1TonBasecamp's Avatar
1TonBasecamp
1TonBasecamp is offline
Can you post up a picture of the starter area of the engine? Or just the whole engine anyway, since we like pics of trucks around here!
What exactly did not fit with the new starter?
Paul
dbarr
03-07-2019 11:16 AM
diymirage
1978 - 1996 Big Bronco
06-27-2017 06:20 PM
Relics
17
12-29-2009 10:26 PM
red85f250
07-12-2004 07:09 PM
Quick Reply: 79 351w starter support brace
