Shuttering
Old May 20, 2020 | 11:51 AM
Rodneywh1970's Avatar
Rodneywh1970
Shuttering
I have a 97 7.3 when I let off the throttle the engine shutters real bad then smooths back out. If I let off easy it doesn't happen only when I let odd fast. Please help. Any ideas of what it could be. Check engine light comes on but it doesn't set a code.
Thanks, Rodney
Old May 20, 2020 | 12:40 PM
z31freakify's Avatar
z31freakify
Check your drive shaft Ujoints and center carrier bearing.
Old May 20, 2020 | 12:45 PM
Rodneywh1970
It does it in park. Will idle for an hour and not do it but if I Rev it it shutters as the rpms drop.
Old May 20, 2020 | 12:48 PM
BuddyBarnes's Avatar
BuddyBarnes
If CEL comes on you probably have a code. You reader just can't read it unless the reader is for these trucks, like AE or forscan and others. Cheep walmart or parts house will not work.
Old May 20, 2020 | 12:52 PM
Rodneywh1970
Well it's not a cheap scan tool. It's an autel 906bt. $2500.00 when I bought it two years ago.
Old May 20, 2020 | 12:53 PM
Rodneywh1970
Check engine light goes out as soon as it smooths back out.
Old May 22, 2020 | 06:05 PM
tgbriggs16's Avatar
tgbriggs16
Hi Rodney,
Mine did this when I got it about a year ago-- I'm assuming it's dropping to just above 500 RPM on the shudder? I had no codes but I'd check your engine valley (particularly your lift pump and the associated hoses) for fuel leakage. This ended up being my problem so I replaced them and the shudder is gone for good.
Old May 23, 2020 | 09:41 AM
tgbriggs16's Avatar
tgbriggs16
Now that I think about it more, I also replaced the valve cover gasket on one side due to corrosion in the electrical plug there at the same time. Corrosion in the plug to the injector on one of the cylinders is more likely to have been the cause of the shudder when I think about the system.
Hope one of these ideas helps!
MinutemanCO
59
Mar 15, 2020 01:52 PM
Brandon Keese
Feb 16, 2019 02:27 PM
messeswithtrux
Jun 16, 2008 05:10 PM
JoBoOtSdEfAyGo
1997 - 2003 F150
May 3, 2007 11:13 AM
Barryrod
Modular V8 (4.6L, 5.4L)
Oct 30, 2004 07:10 PM
