not upshifting
Old May 20, 2020 | 11:17 AM
akpolaris's Avatar
akpolaris
not upshifting
Intermittent problem at the moment but ….. When initially starting the truck remains in 1st gear, not upshifting as acceleration occurs. The speedo will not work during this time. I haven't quite figured out the sequence much better than this. I stop and go to park, back to drive and a reverse to mix things up. It is a 97 F350, 7.3 ltr, automatic trans. Any ideas where to start
Thanks
Old May 20, 2020 | 01:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That can be the VSS (vehicle speed sensor) in the rear axle, or the PSOM (Programmable Speedo/Odomemter Module) located on the back side of the instrument cluster. Or it is an intermittent problem with the wiring between those two.
Old May 20, 2020 | 09:00 PM
akpolaris's Avatar
akpolaris
thanks, something to look at I guess. Is there a way to test these sensors other than replace and see if there is a change?
Old May 22, 2020 | 03:12 PM
Mark Kovalsky
The VSS can be check for resistance. I don't know how many ohms it should be, but it's on this site somewhere. You can also remove it from the differential and see if there is a bunch of metal stuck on it, it is a magnet.
The PSOM isn't a sensor, it is a microprocessor. You can remove it and open it to see if any of the components inside show leakage.
Old May 23, 2020 | 05:41 PM
John11.25's Avatar
John11.25
If you determine that the PSOM may be the problem, You can get a rebuilt one from Clusterfix.net, Ford doesn’t sell them.
After replacing the VSS and pigtail, I replaced the PSOM using this company last year. So far it has corrected the shifting issue I had.
I was getting a P0500 code.
Old Aug 5, 2020 | 10:51 AM
akpolaris2's Avatar
akpolaris2
I replaced the VSS and pigtail. Still an issue. I wet under the dash and looked for the PSOM and rapped on what I think was it with a screwdriver a couple of times. Shifting fine for the moment. Possibly looking for a PSOM next. Rockauto does not carry them..
Old Aug 5, 2020 | 11:07 AM
DanielT28's Avatar
DanielT28
Sounds like we are in the same boat. I’m having similar issues.
my speedometer was bouncing from 0 to 90 miles an hour, my overdrive light was flashing, and ABS light was on.
I took my PSOM out yesterday. I had a bad capacitor. luckily I have a friend who works on circuit boards, he replaced it and the speedometer is food once again. But mine overdrive light is still flashing so I’m trying to figure out what’s going on.
what type of vehicle speed sensor did you use? Ithe ones I tried will not work. When I install any other speed sensor other than the one that came with my pick up,the Speedometer does the output speed at all. PARTS store ones or OEM ones from Ford
If you look closely to the right of the black square the capacitor has shrunk or expanded. so the shrink wrap around it Isn’t covering the top anymore
New one
Old Aug 5, 2020 | 05:36 PM
Mark Kovalsky
I predict that unless you read the codes that you won't be able to fix this.
Old Aug 6, 2020 | 07:56 AM
bbyrnes1's Avatar
bbyrnes1
https://clusterfix.net/store/product...-style-gauges/
marshallyeeyee
Oct 1, 2019 09:45 PM
greg mclaughlin
Apr 22, 2017 07:46 AM
seanb603
Oct 11, 2006 09:20 PM
breisr
Jul 29, 2006 02:24 PM
