Oil leaks
Old May 26, 2020 | 10:43 AM
  #31
Diesel__girl's Avatar
Diesel__girl
Its not the glow plugs entirely, but they contribute to the problem.
Timing (when combustion takes place) in a diesel is controlled by the fuel injection event. The fuel is injected just before we want the explosion.
When we put a flammable vapor in the intake air, we lose control of timing and the combustion event can occur while the piston(s) are on their way UP. This is akin to hitting the top of the piston with a sledge hammer and BAD things can happen (broken pistons, bent rods, etc).
If your truck is a 99-01, you can watch the oil pressure gauge on the dash. The truck will not start until after it builds pressure (then the HPOP can build pressure).
Sometimes it can take quite a bit of cranking.
Do your SES and WTS lights come on and go off when you turn the key on?
Oh wow, I had no idea. Yes my both lights do come on. When trying to crank the belts and stuff turn very slow, not sure if that's normal. I was just assuming that's because its not able to start??
Old May 26, 2020 | 11:27 AM
  #32
RacinJasonWV's Avatar
RacinJasonWV
I’ve heard you need a decent speed to fire up a 7.3.
Your batteries may be low at this point. Have you tried putting them on the charger for a while?
Old May 27, 2020 | 12:43 AM
  #33
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
What Jason said. Charge the batteries. By the book they should be 10.5 volts or better while cranking for the PCM to allow the injectors to fire.
But mine has started at just 8.5 volts, so who knows.
Also depending how cold it is there (how cold is it?) it will help to plug in the block heater. Find the cord by locating the thick orange wire near the oil filter and following it forward.
Old May 28, 2020 | 10:56 AM
  #34
Diesel__girl
Thanks guys. I don't have a battery charger on hand. Gonna borrow one and try it again. It isn't cold here, my truck won't start when it is. I don't have a block heater anymore. Mine got burnt up. Not sure how. While I was under the truck doing the oil change I noticed the cord was dirty and corroded. Went to wipe it off and the cord just broke instantly. Had so much oil underneath the truck that Im guessing it just burnt it up. Plan to fix that somewhere down the line once I get the truck up and running again. Any advice on that??
Old May 28, 2020 | 11:21 AM
  #35
RacinJasonWV
At this point I highly suspect your no start condition is due to low batteries and slow cranking speed.
You shouldn’t need the block heater if living in a warm climate. I rarely use mine (live in WV) but also keep it in the garage and don’t usually drive it in the winter.
I quickly looked in the tech folder https://www.ford-trucks.com/forums/1...-7-3l-psd.html but didn’t see anything related to replacing the block heater, only R&R of the entire cooler. I believe the wire itself is replaceable depending on where it broke.
Slightly off topic...your hands are awfully clean for working on a 7.3. Just kidding!
Old May 28, 2020 | 11:51 AM
  #36
Walleye Hunter's Avatar
Walleye Hunter
I don't know if that's a part of the coil in your hand or just the cord but the cord comes off the heater and is a replaceable item.
Old May 29, 2020 | 02:20 PM
  #37
brian42's Avatar
brian42
Veteran: Navy
These are the specific parameters that the PCM is looking for before it gives the green light to the IDM to fire the injectors and bring the big block to life (these are all minimums while cranking):
1. Engine RPM - 100
2. Injection Control Pressure (ICP) - 500 psi
3. Injection Pulse Width (PW) - 0.6 ms
4. Volts - 7-10 VDC
There are nuiances between years but these are the four basic things your truck PCM needs to see while cranking before the IDM gets the go ahead to start injecting fuel
Note: The 0.6ms pulse width requirement indicates that the PCM and IDM are talking and not an indication of actual pulse width. If the PW was 0.0ms then the IDM did not answer when the PCM called so it left a voicemail telling the IDM there will be no injection action this round.
Old May 30, 2020 | 02:45 AM
  #38
aawlberninf350
It's a Van Gogh
Replace the cord then plug it in for a couple hours before attempting to start.
What are the temps wherever you are overnight? Actual numbers please.
Old May 30, 2020 | 02:01 PM
  #39
Diesel__girl
Ha ha, my hands rarely look like that. This was at night time before bed and those pieces have been sitting in the house for over a week. I did get a battery charger. Still no start. I do believe it is my Ipr. I went cheap and bought one off ebay. Rookie mistake I guess. Soon as I can afford one, Im going to get a high dollar motorcraft. The one thats on there now I can't get the tin nut to tighten. It just keeps turning and turning...junk. Im not sure tho how I'm going to change that without taking the hpop and all off again, sure is tight
Old May 30, 2020 | 02:04 PM
  #40
Diesel__girl
The part in my hand is the very end of the cord from under the truck and the clamp to hold it in. Mine comes from the oil filter housing under the truck. It broke off right as it goes in, and I just took the clamp out for keeping in case I can reuse. But it is the very tip from under the truck
Old May 30, 2020 | 02:09 PM
  #41
Diesel__girl
1. Engine RPM - 100
4. Volts - 7-10 VDC
I don't have a way of testing all this..What do you all use. I've heard some use a volt meter with an app downloaded on their phone. Not to sure about any of them. Any advice on the best way to go about this would be greatly appreciated. Not a mechanic by any means. Just learning as I go and appreciate any and all help I can get
Old May 30, 2020 | 02:11 PM
  #42
Diesel__girl
I believe my problem right now is the Ipr, went cheap on that and realizing now that was a big mistake. It does get cold here but as of rite now the temps shouldn't affect it. Summer has hit here and only about a 60 degree or better low here of the evenings now
Old May 30, 2020 | 02:15 PM
  #43
Diesel__girl
Also wanted to add that when Im trying to start the truck, while cranking I noticed it takes a few for the gauge on oil pressure to move...not sure if that's normal or if the gauge should move instantly??
Old May 30, 2020 | 03:11 PM
  #44
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Check out my Denso starter video below. The cold/first start does not show the oil pressure gauge, but the warm/second start does.
How does your gauge compare?
Old May 30, 2020 | 04:03 PM
  #45
RacinJasonWV
How does your gauge compare?https://youtu.be/h3LsuCmaD-4?list=PL...JZEE-Kv1XAzSir
Wow Sous. I guess the Denso starter is on my wish list now. That spins it over really fast!
Diesel_girl, I’m not sure if you’re familiar with them but riffraff Diesel is a good source for parts. https://www.riffraffdiesel.com/ipr-i...gulator-96-03/
Unfortunately the IPR isn’t a cheap piece. I consistently hear from folks (here and elsewhere) to only use Ford or International sensors in our trucks.
