Oil leaks
Old May 30, 2020 | 05:58 PM
  #46
jstihl's Avatar
jstihl
Originally Posted by Diesel__girl
Ha ha, my hands rarely look like that. This was at night time before bed and those pieces have been sitting in the house for over a week. I did get a battery charger. Still no start. I do believe it is my Ipr. I went cheap and bought one off ebay. Rookie mistake I guess. Soon as I can afford one, Im going to get a high dollar motorcraft. The one thats on there now I can't get the tin nut to tighten. It just keeps turning and turning...junk. Im not sure tho how I'm going to change that without taking the hpop and all off again, sure is tight
if you can't spin the ipr nut off you might be able to get some snips or dikes down there and cut the nut then bend it off. Those nuts are not very strong.. Once that comes off , slide the solenoid off and then take a 1/2 inch drive 29mm deep well socket and remove the remaining part of the sensor. Socket has to be extra deep, they sell them at oriellys , its called a axle nut socket. It would be a bummer to Remove the whole hpop just to remove the sensor
Old Jun 18, 2020 | 07:11 PM
  #47
RacinJasonWV's Avatar
RacinJasonWV
Any updates?
Old Jun 18, 2020 | 10:10 PM
  #48
bigb56's Avatar
bigb56
Originally Posted by Sous
Check out my Denso starter video below. The cold/first start does not show the oil pressure gauge, but the warm/second start does.
How does your gauge compare?https://youtu.be/h3LsuCmaD-4?list=PL...JZEE-Kv1XAzSir
That sounds great Sous, I wonder if that starter might eliminate my occasional ring gear grinding? Or make it worse
Old Jun 18, 2020 | 10:18 PM
  #49
SteveZ's Avatar
SteveZ
Dumb question for you. Have you checked the oil? If it is leaking a lot you may not have enough oil for the injectors to work.
Jessef250
15
May 25, 2020 10:14 PM
Neilwatkins1000
19
Jan 6, 2020 07:07 PM
09dewaed
Sep 17, 2018 09:05 AM
id_birdhntr
Sep 25, 2012 06:13 PM
SilverDually
Mar 10, 2004 11:58 PM
