Air Bags
Old May 16, 2020 | 06:33 PM
STX7.3's Avatar
STX7.3
Air Bags
Air lift or Firestone? I’ve seen figment issues with firestone on 20’s, but haven’t seen that resolved? Which brand is better Quailty?
Old May 16, 2020 | 06:50 PM
Gallows's Avatar
Gallows
Firestone updated the kit for the 20's. A couple members on here installed them with the new brackets.
Old May 16, 2020 | 06:51 PM
Lamoon78's Avatar
Lamoon78
I have been using Firestone bags for years with no issues.
Old May 16, 2020 | 06:58 PM
Rich53's Avatar
Rich53
I just put the Firestone red label on my 2020 F350 CCSB 6.7L FX4 with no issues. I would say that I didn’t do as good a job as I should have getting the lower bracket tight against the spring pack, so the ears on the bracket ended up bent in when I tightened up the UBolt for it, but it all seems to work fine, ran it around with 80psi in it for a few days to make sure no leaks, and the bags are all sitting nice and true to the mounts.
Old May 16, 2020 | 07:34 PM
pwrandspd's Avatar
pwrandspd
I have a set of Air Lift on my '17 that have worked well for me.
Old May 16, 2020 | 08:04 PM
Brother_Bluto's Avatar
Brother_Bluto
I put Airlift on my 2017 F350, and again on my 2019 F450. Been very happy with them, and their customer service is great. Both bags were the 5000 Ultimate+ versions (with the internal jounce bumper). I'm not sure about the 2020 versions... but on the prior model if you had the rear wheel well inserts, you had to trim them with the Firestone bags.
Old May 16, 2020 | 08:28 PM
Rich53's Avatar
Rich53
On the 20’s no trimming with the Firestone’s, they go on the inside.
Old May 16, 2020 | 10:09 PM
Gallows's Avatar
Gallows
https://www.ford-trucks.com/forums/1...stall-tip.html
Old May 17, 2020 | 12:43 PM
STX7.3's Avatar
STX7.3
Thanks for the replies.
Old May 17, 2020 | 04:34 PM
spinningwheel's Avatar
spinningwheel
Thanks for the link, it helps a lot.
Old May 17, 2020 | 05:37 PM
ForCal's Avatar
ForCal
The actual air bag installs I've seen look straight forward and fairly simple, but it would be interesting to see various compressor, control and auxiliary tank install locations and ideas, along with wiring and routing necessary.
It would be nice to not only have the added benifit of the air bags, but also onboard air that could keep up with airing up tires and possibly even power some pneumatic tools. I know its somewhat common to do, the air bag install videos Ive found seem to gloss over the details after installation of the bags themselves.
Old May 17, 2020 | 06:39 PM
SuperDuty Wannabe's Avatar
SuperDuty Wannabe
I carry a Truck Camper and install Air Bags on every new truck. I chose Pacbrake Airbags this time around for my 19' F450. Very impressive, similar to my previous Helwig Bags on my 17'. Substantially Heavier built the my previous Airlift or Firestones.
adelatorre204
All Things Towing
Jan 27, 2020 11:30 PM
Tuquala
Dec 17, 2016 11:34 AM
Doonz
6.7L Power Stroke Diesel
Feb 26, 2014 09:20 PM
Mpotinc
May 6, 2012 08:37 PM
rvpuller
Nov 24, 2004 01:48 AM
