Truck not starting
Old May 1, 2020 | 09:30 PM
Jeremiah Elmore's Avatar
Jeremiah Elmore
Truck not starting
I have a f250 7.3 the truck will crank but wont start also if i use starting fluid it will turn over but wont stay running if u can point me in the right direction to get it running thanks
Old May 2, 2020 | 02:50 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
First off, welcome to FTE!
What year is the truck?
My first guess is a bad CPS. You can replace that pretty easy and cheap.
Is the check engine light on? If yes, got a way to pull that code?
So now it won't start, but how did it get there? Running perfect then zilch?
Old May 2, 2020 | 07:14 AM
Listor's Avatar
Listor
and please stop using starter fluid!
Old May 2, 2020 | 07:56 AM
pirschwagon's Avatar
pirschwagon
Begin with the attachment
Old May 2, 2020 | 08:51 AM
tommyl's Avatar
tommyl
check your fuses
Old May 2, 2020 | 08:52 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
In addition to what Pirschwagon and the others have suggested, a "No Start Flow Chart" is available in the 7.3L PSD Tech Folder as well as a lot of other good information. I have included a link directly to the No Start Flow Chart for your quick and easy viewing below.
No Start Flow Chart
Old May 4, 2020 | 04:50 PM
Jeremiah Elmore
no check engine light was running fine then nothing
Its a 02 with 260k. I was thinking bad diesel i put it in before i turned it off then nothing tried jumping it the truck did get stolen like 4 months before and its sat for about 6 months
Old May 5, 2020 | 06:56 AM
tommyl's Avatar
tommyl
Best bet, go thru the "no start flow chart" step by step. then report back your findings.
Old May 6, 2020 | 01:40 AM
aawlberninf350
It's a Van Gogh
With no codes I'd suspect a bad fuel pump.
Fordguy1974
1997 - 2003 F150
Nov 15, 2019 11:41 AM
Amart927
Oct 15, 2019 12:28 PM
idi1993f350
Apr 18, 2017 05:21 PM
Ed's 95 7.3
26
Jan 26, 2013 06:37 PM
jfkstowing
Aug 21, 2005 01:22 PM
