Engine light
Old Apr 29, 2020 | 01:50 PM
Redrumrevolution1's Avatar
Redrumrevolution1
Engine light
I have a 2012 Ford e-150 with the 4.6. I recently just changed out fuel pump because fuel level sensor went out. After replacing and fueling up on the second fill up engine light came on reading P0150. It had a slight hesitation after taking off from the pump but ran normal afterwards. The light turned of the next morning. I filled up the 3rd time and the light came on again same issue but code read P2196. Any possible issues that I should looking towards?
Old Apr 29, 2020 | 01:53 PM
Spaznaut's Avatar
Spaznaut
What are those codes? Did you replace the fuel filter when you did the pump?
Old Apr 29, 2020 | 02:06 PM
Redrumrevolution1
P0150 indicates the O2 sensor 1 for bank 2 fails to meet the minimum or maximum voltage limits calibrated into the Ecm
P2196 indicates that there is too much fuel in relation to the oxygen in your vehicles bank 1, or that the oxygen sensor is faulty and reading an incorrect air/fuel ratio.
Didnt replace fuel filter
Old Apr 30, 2020 | 05:39 AM
JWA's Avatar
JWA
Here's a great site for deciphering DTC's: DTC Reading
What are your real time long and short term fuel trims? What is the relative rail fuel pressure? I'd change the fuel filter just because its a good practice with all else you're done so far.
1989fordguy
Feb 21, 2013 05:06 PM
planofootball19
Mar 3, 2012 11:19 AM
jcranston
1997 - 2003 F150
Jan 26, 2012 02:54 PM
backdraft341
2004 - 2008 F150
Nov 23, 2010 09:18 AM
shajoe44
Jul 4, 2004 11:34 AM
