Window slow to roll down
Old Apr 23, 2020 | 11:13 AM
Mikec35's Avatar
Mikec35
My drivers window rolls down normal until it gets about halfway down then it slows down to the point that I feel like something is going to break then I stop trying to roll it down. I have noticed that when it's been raining it rolls all the way down without issue. I suspect the rubber channels on the front and rear edges of the window may be the problem. I'm going to try silicone spray in the channels. Just checking to see if anyone else has experienced this issue or something similar, should I take the door panel out and grease the rollers or check something else? Thanks
Old Apr 23, 2020 | 11:48 AM
CousinCarl's Avatar
CousinCarl
Silicone on the rubber channels helped mine. I've also had motors go out (likely from working against the dried out channels) that I've had to replace. Anytime I am in the door panel for some other work, I spray them down.
Old Apr 23, 2020 | 12:52 PM
FordTruckNoob's Avatar
FordTruckNoob
Also check the alignment of the window regulator.
Old Apr 23, 2020 | 01:51 PM
Dan V's Avatar
Dan V
Silicone spray...wonderful
Old Apr 25, 2020 | 10:27 AM
Mikec35's Avatar
Mikec35
Spray did it.. it's not perfect but it rolls up and down. I'll remove the door panel and check/lube the rollers. Probably should replace the channels one day, when I'm not so busy
Old Apr 25, 2020 | 02:29 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I usually lubricant the driver side window channels 3-4 times per year. I am too lazy to replace the channel since a combined time investment is less than 5 minutes per year.
If you decide to replace the channel, let us know your thoughts on the job.
Good to see no more ghosts in your truck.
Old Apr 25, 2020 | 04:03 PM
Dan V's Avatar
Dan V
Changing the glass runs...not that big of a job, I just swapped mine from doors...had the glass out though.
Old Apr 26, 2020 | 09:30 AM
Mikec35's Avatar
Mikec35
I left the silicone spray in my truck box incase I need it again.. I am sure I will.
Yes! The Ghost's have not returned!
Old Apr 27, 2020 | 01:59 PM
AubieTN's Avatar
AubieTN
Hey guys, thanks for info using silicone spray, thought I had a motor issue but as y’all mentioned it would go down easy when it rained. I simply rolled all four windows down, almost all the way then sprayed the silicone in the two channels on each window. Did that at each window, cycled each window up/down a couple times and did the process a second time. All is well with my windows now.
Thanks again brothers.
Aaron_Jones
Jun 17, 2016 09:54 AM
gradyc
Apr 12, 2010 08:01 PM
putter
Jan 30, 2010 04:41 PM
f-150 on 22's
2004 - 2008 F150
Sep 4, 2007 09:11 AM
jhromy
Oct 27, 2004 08:37 AM
