Chattering power window
Old Apr 12, 2010 | 05:19 PM
gradyc's Avatar
gradyc
wellhead
O.K. I have had this chattering driver side window for some time. Yesterday I pulled off the door panel and greased all the channels I could find. All back together.
Still chattering but not as bad. What have I missed?
Old Apr 12, 2010 | 07:05 PM
twags6's Avatar
twags6
There's a special lube you can get from ford that goes on the felt window tracks. I remember Dan (kwikkordead) mentioning it a long time ago, but can't remember the specifics.
Old Apr 12, 2010 | 07:06 PM
aquartlow's Avatar
aquartlow
Try using silicone spray on the vertical window felts, it does wonders. Make sure you get the type that dries with no residue, un-like what WD-40 would leave. I believe the spray I used was called Jiggaloo(what a name). Some silicone sprays leave a white stain after drying, so try a little on your fingers and see if it dries clear with no residue. I hope this helps.
Old Apr 12, 2010 | 07:12 PM
Kwikkordead's Avatar
Kwikkordead
One of the first things that I did for my truck was to lube the window tracks because the driver's window was very sluggish rolling up.
That was five years ago now, wow, time flies.
What I used was silicone faucet lube in the track.
Basically a 100% silicone based waterproof grease.
Still rolls up and down as quickly as the day that I did it.
I've never had a chattering window, but I'll bet the gear is stripped in your window regulator.
You'll have to replace the window regulator to fix that.
twags6's Avatar
twags6
Yeah, dunno what I was remembering but aquartlow has the right idea. Silicon spray seems to be the popular fix.
Old Apr 12, 2010 | 07:40 PM
aquartlow's Avatar
aquartlow
My window would go up smoothly until the last couple of inches but on the way down it would jiggle front to back like a loose track or binding. Once I used the spray all was good. Wait till you see how fast the windows move after you spray the window felts(vertical tracks). I hope it works as well for you.
Old Apr 12, 2010 | 08:01 PM
4inchlovin's Avatar
4inchlovin
Silicone spray here....
hmmmm maybe i shoulda thought a better way to phrase that...hehehe
F350AgInspector
Escape & Escape Hybrid
Jan 16, 2012 06:01 AM
west tn 6.0 powerstroke
Apr 17, 2010 11:53 AM
bkeenan
New Member Introductions
Sep 16, 2009 03:50 PM
Placermike
Washington Chapter
442
Jan 18, 2008 03:32 PM
