lube up window track
Old Oct 27, 2004 | 07:40 AM
jhromy's Avatar
jhromy
I have an 02 explorer which both front windows rattle and its pretty annoying...ford keeps telling me that they lubed the tracks up..I doubt that they really do it so i decided ill do it...I just need to know what to use to lube it up..any suggestions???
Old Oct 27, 2004 | 08:11 AM
holland501's Avatar
holland501
Window rattles are not usually a sign that you need to lube the window tracks. It sounds like something is loose/worn in the window mechanicals. Pull the door panel and look for yourself. As for what to lube things with. I use spray silicone for the felt tracks the glass rides in and grease for the gearing and slideing parts in the door. Good luck.
Old Oct 27, 2004 | 08:37 AM
jhromy's Avatar
jhromy
i have had the regulators replaced atleast 3 times in each window and it will go away for about a month and then come back...i guess ill keep bugging ford to fix it
