Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Jump Starters
Old Apr 22, 2020 | 10:57 AM
TexGuy's Avatar
TexGuy
Jump Starters
I'm thinking of buying an auto jump start box for my escape. Is this big enough or Do I need bigger? Stanley Fatmax 700/350 amp jump starter?
Old Apr 22, 2020 | 11:08 AM
ford390gashog's Avatar
ford390gashog
The one you want to buy is pretty useless as are all the wet battery models. Look at something like the NOCO GB50 OR GB150.
Old Apr 22, 2020 | 04:49 PM
cmorningstar01's Avatar
cmorningstar01
I think a spare battery and a decent set of jumper cables is less money and more efficient.
If you can find the room under the hood you could always add a second battery with a cutoff switch, turn the switch on occasionally to keep the battery charged and off during general use in case you leave your lights on or have some other battery draining occurrence
Old Apr 23, 2020 | 02:46 PM
PupnDuck's Avatar
PupnDuck
The first question I'd ask is why you think you need this. Is your existing battery flakey? If so, the money would be better spent on a new battery. But then if you're in the habit of leaving things on that kill the battery, well that's a different story. Also be aware that unless you have a deep cycle battery in your vehicle, normal automotive batteries don't live very long if they're repeatedly run down to the point that they won't start the vehicle without a jump.
Old Apr 23, 2020 | 05:18 PM
clintbonnie's Avatar
clintbonnie
X2.... Also you can get yourself a hydrometer, less than $10 and check each cell in the battery periodically (if it is a wet cell battery..) Any low readings, get a new battery... See: https://www.oreillyauto.com/detail/b...ometers+&pos=0
Old Apr 26, 2020 | 03:10 PM
TexGuy's Avatar
TexGuy
The reason I was thinking of getting a jump starter is because I just don't drive much anymore. However after watching some youtube videos I don't think it's worth getting one and I do have Allstate road service.
Old Apr 26, 2020 | 08:47 PM
PupnDuck's Avatar
PupnDuck
If you use your car infrequently, you might look into a solar trickle charger / battery maintainer. That Texas sun should keep your battery topped off nicely.
Old May 6, 2020 | 04:59 PM
TexGuy's Avatar
TexGuy
I'm going to a food store 3 miles away now and not the store 1 mile away, lol
Old Nov 6, 2021 | 05:44 AM
got2bjoester's Avatar
got2bjoester
I side with PupnDuck. I would get something along
these lines these lines
and use it. Simple solar charger you can set on the dashboard and plug into your cigarette lighter plug (most Escapes are always on).
Old Jun 3, 2024 | 02:20 AM
HankMurphy's Avatar
HankMurphy
Not on A SD, but I had a problem with parasitic drain on a 1992 F150. I got a giizmo which had a small fuse and two connections to the battery positive. One connection was switchable (actually a bolt which you would tighten to make normal contact with the battery),
. The other connection was always hot - well, maybe only a little warm - and fed the truck electrical system normally, but had a small fuse to limit the amount of power provided. ( I think 2.5 amps.). Radio station memory was preserved, but try to start and the small fuse would blow.
I wish I could remember more about it, but something like this could solve the OP’s problem.
Motohead911
Oct 6, 2018 04:26 PM
hellbound_redneck
Jan 25, 2010 07:39 PM
Fomoko1
Jan 10, 2009 12:39 AM
wolffee
Oct 27, 2008 05:34 PM
2word
Jun 12, 2002 07:35 PM
