Ignition Cylinder Stuck
Old Apr 16, 2020 | 07:58 PM
jeffw33's Avatar
jeffw33
Question Ignition Cylinder Stuck
I have a 61 F-100 that has not ran in several years. The key/cylinder is stuck in the on position. It will turn to start, but will not turn back to off or accessory. Everything I have found so far describing how to remove the cylinder says to put the key in the accessory position and insert a paper clip or wire. I have tried, but I believe because I am unable to turn it to accessory, it is still not coming out. Any ideas on how to remove it without drilling it out? Thanks
Old Apr 16, 2020 | 08:49 PM
wauto's Avatar
wauto
Look up on the internet on how to "bump" locks. Squirt a little penetrant in around the key and bump it backwards.
Old Apr 16, 2020 | 09:42 PM
woodsmoke's Avatar
woodsmoke
Kroil is your friend.
Old Apr 17, 2020 | 04:27 AM
User 71024's Avatar
User 71024
are you sure you have the right key? If it were a warn out lock some one could have removed the key while it was in the ON position, and you could be trying the wrong key. Just a thought.
Old Apr 17, 2020 | 09:29 AM
William's Avatar
William
Dang, good one EricJ.
Old Apr 17, 2020 | 12:02 PM
jeffw33's Avatar
jeffw33
It's the right key
DieselCamper
24
Oct 6, 2017 02:08 PM
ZombieSlayer
1978 - 1996 Big Bronco
Mar 7, 2014 10:08 PM
march
20
Jan 2, 2014 07:46 AM
Old_Ford_Man
Feb 11, 2011 03:53 PM
mnm1997
Electrical Systems/Wiring
Dec 8, 2000 07:31 PM
