Question About Changing Ignition Cylinder
Old Feb 10, 2011 | 10:33 AM
Old_Ford_Man's Avatar
Old_Ford_Man
I got all new door locks and ignition cylinder for my 66 F100 and I got the door locks changed out no problem but the ignition cylinder is not wanting to come out. I turn it to accessory position and then used a paper clip to push in the small hole to unlock ignition cylinder but it just will not come out so what am I doing wrong?
Old Feb 10, 2011 | 11:03 AM
CropDusterMan's Avatar
CropDusterMan
You'll just have to fiddle with it until it does...that's what I did...it just took a lot of patience. They do make a tool for it, but can't see how it would work much better.
Old Feb 10, 2011 | 11:48 AM
Old_Ford_Man
I did the one on my 65 Mustang and it poped right out but that was about 21 years ago when it did that and I am a little foggy on the steps. So lets make sure I am doing it right
1. Do you insert the paper clip into the hole of the ignition cylinder and then turn the key to the accessory position and then try to remove the ignition cylinder
Or
2. Do you turn the key to the accessory position and insert the paper clip into the hole of the ignition cylinder and then try to remove the ignition cylinder.
Old Feb 10, 2011 | 01:18 PM
Boss9F100's Avatar
Boss9F100
Or
turn to accessory then push on pin just hard enough to move it, then continue turning key to left (counter clockwise) and it will come out in your hand. once it starts to move counterclockwise you can release pin/paperclip its that simple. for install just put key/cyl in and turn towards on and done.
Old Feb 10, 2011 | 01:37 PM
Old_Ford_Man
Thanks I will try it again when I get home.
Old Feb 11, 2011 | 12:01 PM
daveengelson's Avatar
daveengelson
With key in ignition, insert the paper clip and then rotate the lock to the Acc. position, the key assembly should come out, they can be difficult but be carefull, there's a pin on the end of the key assembly that fits into a slot in the ignition switch, the tolerance is very close and can only go in 1 way, this is why you want the key in the 'accessory' position to install. Horrible explaination but makes sense after key assembly is removed.
Old Feb 11, 2011 | 02:13 PM
Boss9F100's Avatar
Boss9F100
That is not the proper way. Turn key to acc then push detent and continue to turn counterclockwise. Just as I stated above...
Old Feb 11, 2011 | 03:53 PM
daveengelson
Sorry, you are correct, still keeping in mind the replacement assembly needs to be in same position when installed.
