Need help messege back with advice
Old Apr 15, 2020 | 06:11 PM
  #31
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Take your belt off the truck, find a 2' breaker bar with 1/2" drive, socket and extension to fit the bolt on the harmonic balancer. Try to turn the engine over by hand going clockwise. Does the engine rotate by hand? If not then something is wrong internal to the engine itself.
Old Apr 15, 2020 | 08:00 PM
  #32
Jeffturner903's Avatar
Jeffturner903
Removed both belts turned crankshaft so i dont think its locked up turned all pulleys the powersteering pump pulley stuck a little but still turned and the air pump pulle did the same it tried cranking tho until fresh battery died havent tried to roll start without belts tho ran out of daylight
Old Apr 15, 2020 | 09:30 PM
  #33
torq'ta 5 8's Avatar
torq'ta 5 8
Originally Posted by Jeffturner903
Also could it be the entire battery cables cause sometimes they get hot during the click or jump the solenoid but still nothing more than a click
when you replaced starter, had you been having the click no crank issue, is why you replaced it, see link below it shows how to test for good grounds, and positive 12
volts
Classic Broncos .com - Tech: Basic Vehicle Electrical Diagnosis for 66-77 Early Ford Bronco
Old Apr 15, 2020 | 10:17 PM
  #34
sandymane's Avatar
sandymane
If your starter didn't line up when installed the starter gear may not be engaging the flywheel. This would cause your problem. If you can't see starter gear, drop the starter and have someone crank it and see if the gear spins. If so, you have bypassed the click. Either wrong starter or if the old one had shims and you didn't reuse them it got misaligned when installed would be my guesses. Another thing you can do is try to jump start it. If it turns over or starts you know it's a bad battery, bad connections or loose ground connection to the motor. I would try jumping it before starter check but I think it's the starter, if it's either one of them. Sandy
BE CAREFUL OF THE STARTER GEAR SPINNING IF YOU DROP IT OUT AND TRY TO START IT.
Old Apr 17, 2020 | 07:24 AM
  #35
tjc transport's Avatar
tjc transport
i ain't rite
charge battery.
put trans in neutral, and set parking brake. open hood. take a screwdriver and cross the small push on stud terminal and the large lug that the battery cable is on. if the engine turns over, the starter relay is good. if nothing or just the clunk, use a large set of pliers and jump across the two large lugs on the relay. NOTE: it will spark!!
if the engine turns over, the starter relay is bad.
if just a clunk and big sparks, either they gave you the wrong starter, or the new starter is bad.
do these steps first, and report back what happens.
anthonym92
Nov 12, 2015 05:21 PM
49er_rs
1997 - 2003 F150
Nov 9, 2012 08:54 AM
jaye
Electrical Systems/Wiring
Oct 24, 2012 12:39 PM
airrikk17
1978 - 1996 Big Bronco
Jan 17, 2005 05:40 PM
dw1_hoosier
Aug 22, 2004 01:07 PM
