Need help messege back with advice
Old Apr 13, 2020 | 11:42 AM
Jeffturner903's Avatar
Jeffturner903
I have a 95 f350 with a 7.5 L gas engine with 5 speed manual trans
i have changed out distributor,starter,starter solenoid,plugs,wires,battery ,freshened up battery terminals and and ends, still getting click no crank or start upon ignition. I was driving to work a few weeks ago and the serpentine belt frayed caused truck to lose power and die i changed all the parts myself mentioned above and now im at a loss cant get it cranked to see if parts helped out initial sluggish problem fuel pumps cone on when turn key and everything else does right but when u turn key to start just the dreaded click ive tried jumping the truck off ive crossed the solenoid ive done everything i can think of any help would be great thanks
Old Apr 13, 2020 | 12:01 PM
sandymane's Avatar
sandymane
Check for spark?
Old Apr 13, 2020 | 12:12 PM
Jeffturner903
Dont have the tool to do so
Old Apr 13, 2020 | 12:17 PM
88n94's Avatar
88n94
If you are sure the battery posts are good and clean and the terminals tighten up properly follow the negative battery cable and clean the connection at the other end.
Old Apr 13, 2020 | 12:26 PM
Jeffturner903
Is there any other grounds i may have missed causing this besides the one from block to firewall and battery to fender?
Old Apr 13, 2020 | 12:42 PM
sandymane's Avatar
sandymane
If the truck will not start, pull the spout out and see if it starts. Sandy
Do what the guys above said they are two of our best. I thought the truck was now turning over. Sandy
Old Apr 13, 2020 | 12:46 PM
rla2005's Avatar
rla2005
The main power ground goes from the battery negative terminal down to the engine block. There is a small splice on the way there that goes to the frame, but it is used for trailer towing only.
Old Apr 13, 2020 | 01:10 PM
Jeffturner903
Ok what is the spout sandy?
Old Apr 13, 2020 | 01:46 PM
sandymane's Avatar
sandymane
It it is a little gray connector that you remove to time the truck. It is located near the back of the firewall where the computer is. Just remove it and see if it will start
Old Apr 13, 2020 | 01:51 PM
rla2005's Avatar
rla2005
It's irrelevant since the truck is not spinning (cranking/turning/etc.) over, or at least that is how I interpret your current issue.
Old Apr 13, 2020 | 02:09 PM
subford's Avatar
subford
Just one click means most of the time the starter relay is bad.
You have not said anything about the starter relay just starter solenoid that is mounted down on the starter itself.
Old Apr 13, 2020 | 02:21 PM
subford's Avatar
subford
Also check the spade terminal:
Old Apr 13, 2020 | 02:26 PM
sandymane's Avatar
sandymane
Do what the two guys above said. They are two of our best. I thought the truck was turning over. Sandy
Old Apr 13, 2020 | 06:01 PM
Jeffturner903
Yeah it aint trying to turn over at all turn key and click i have swapped around other relays under the hood and tried still same thing could it be locked up since the belt broke off during driving just maybe pull it to start it and try to free it up?
Old Apr 13, 2020 | 06:42 PM
Jeffturner903
Update unplugged that little gray connecter still same thing unplugged icm still same thing what is the little 2x1 inch rectangle thing called next to starter solenoid on fender it has red and black wire to it? Also could it be the entire battery cables cause sometimes they get hot during the click or jump the solenoid but still nothing more than a click
