Excursion Wiring Question
Old Apr 12, 2020 | 10:43 PM
78CJ5's Avatar
78CJ5
Hi All
I have a 2002 Excursion 4x4 with the 6.8 V10 that I got about 4 months ago. I'm putting in a New Switch Panel with a couple of new Rocker Switches (ie: Front Locker, Fog Lights, Light Bar, Rear Lights all the lights will be LED's, Compressor, Ham Radio) that will run thru a 40 Amp Light Relay. My question is where in the Engine can i get a power source that is on when the Key is on and when the in the accessory side is on? I want to use that as the trigger source for the relay so that the Switch Panel isn't always on.
I would prefer a source in the Engine Compartment but a coming on the interior fuse panel would be ok. Any help or ideas would be greatly approcated.
Thanks
David Phelps
Magalia, CA.
Old Apr 13, 2020 | 05:27 PM
Lance Helmert's Avatar
Lance Helmert
There's the fuse box on the drivers side fender. Otherwise there are 4 wires through the firewall for accessories. I don't remember where they are located though, maybe one of the other members does.
Old Apr 14, 2020 | 09:57 AM
78CJ5's Avatar
78CJ5
Good Morning Lance
Thank You, I'll see what I can find out.
David Phelps
Magalia, Ca
Old Apr 14, 2020 | 11:13 PM
FP3's Avatar
FP3
where is your relay going to be? under the hood, or in the cab? If you're just wanting to trigger the relay, there are a few options inside, in the harness under the steering column, and a few other places. You could even tie it onto the radio if you wanted. I dont recall the colors off the top of my head.
Old Apr 15, 2020 | 11:42 AM
78CJ5's Avatar
78CJ5
Hi FP3
The Relay is under the Hood. All I want to do in trigger the Relay on with the Key in either location.
David
Old Apr 16, 2020 | 11:12 AM
alloro's Avatar
alloro
I believe there is only one circuit from the ignition switch that is live in both the Accessory and On positions, (such as for the radio.) Take a look at the wiring harness from the ignition switch and the wire you want is usually BK/LG. That wire runs from the switch to the CJB where it powers a couple of fuses. From the CJB the circuit then runs to the Battery Junction Box where is supplies power to the wiper relays. So look for the BK/LG wire at the BJB and see if it's live only in the Accessory and On positions.
Old Apr 16, 2020 | 07:36 PM
Lance Helmert
Here are the 4 wires on my 2000. I'm not sure where the ends are under the dash.
Old Apr 18, 2020 | 08:44 PM
Cocky EX's Avatar
Cocky EX
Follow the parking brake up under the dash. That's where mine are.
SVTDarin
Jan 30, 2015 04:46 PM
Dan Jordan
Jan 2, 2010 08:20 PM
trike1946
Electrical Systems/Wiring
May 27, 2008 05:30 PM
travis dasher
Sep 12, 2006 02:27 PM
ubermich
Jun 30, 2004 10:17 PM
