Help installing Hella lights
Old Jan 29, 2015 | 01:32 PM
SVTDarin's Avatar
SVTDarin
I have everything done but the switch and getting switched power. I want to get the switched power from the fuse panel. I didn't see one labeled parking lights and the one I tried "exterior lamps" was no switched with the lights. Which fuse can I tap in to? It's a 02 XLT that does not have factory fogs.
Old Jan 29, 2015 | 02:36 PM
Apocalypse's Avatar
Apocalypse
Personally I would make a whole new harness with relays...
Old Jan 29, 2015 | 02:40 PM
USCG_PA's Avatar
USCG_PA
or just buy one:
Wiring on Amazon Wiring on Amazon
Old Jan 29, 2015 | 02:46 PM
SVTDarin's Avatar
SVTDarin
I have a relay hooked up the 4 relay wires which are RED - battery to relay, BLUE - relay ground, BLACK - to lights, YELLOW - to switch on installed in dash. Then I have 2 other switch connections to make GREEN - switched power (want to get from fuse panel), BLUE - switch ground
I want them to come on when I turn on the parking lights and I guess if I can't get fuse panel power I can tap in the parking light wire if someone can identify it's color and best location to get it.
Old Jan 30, 2015 | 03:12 AM
housedad's Avatar
housedad
I can't remember what I did. Too long ago. Except I used Bussman sealed fuse boxes with mini breakers. Worked great and keeps the wiring mess down.
Old Jan 30, 2015 | 06:34 AM
Apocalypse's Avatar
Apocalypse
Originally Posted by USCG_PA
or just buy one: Wiring on Amazon
Well that yeah
Old Jan 30, 2015 | 08:45 AM
SVTDarin's Avatar
SVTDarin
See my post #4
Old Jan 30, 2015 | 04:46 PM
SVTDarin's Avatar
SVTDarin
FYI solid brown wire at the back of the headlight switch is the one I was looking for. Hellas are now wired and attached to the pre-runner bar.
Flargen
May 17, 2016 03:08 PM
tricky81
Feb 6, 2012 10:42 AM
93FordCTD
Feb 3, 2010 09:25 PM
tomtoc
Aug 12, 2007 03:15 AM
deepbass
1978 - 1996 Big Bronco
Dec 9, 2005 08:57 AM
