I NEED HELP! 2001 7.3L Excursion
Old Apr 8, 2020 | 05:28 AM
mitchellhazelton's Avatar
mitchellhazelton
I was driving home from work the other day and my truck started to bog down got it home because i could only go 40 with it bogging down and now it wont start. replaced the fuel filter already dont know where to start honestly code are pp0683, p1316, p0670, p0678, p0677, p0676, p0675, p0674, p0673, p0672, p0671, p1211, p1247, p1316, p0603,
Old Apr 8, 2020 | 05:45 AM
SkySkiJason's Avatar
SkySkiJason
Look in ICP sensor plug for oil.
Make sure GPCM harnesses are plugged in good.
Look for chaffed wires on 42pin harness.
How much fuel is in the tank?
Old Apr 8, 2020 | 06:22 AM
mitchellhazelton
About 3/4 of a tank
Old Apr 8, 2020 | 06:44 AM
SkySkiJason
Originally Posted by mitchellhazelton
About 3/4 of a tank
That should rule out broken pickup in tank...
The P1316 is most likely the reason for no-start. That is often a death code for IDM. But, I’d like to see buzz test and KOEO, etc to make sure nothing else is going on.
UVCH’s are suspect, but it would be very coincidental for both sides to come unplugged at once (causing all of the GP codes) and ‘low to high side open’ codes are common when they do...
Old Apr 8, 2020 | 08:51 AM
Squirrel13's Avatar
Squirrel13
Diesel Tech Ron had a good video on this
Old Apr 8, 2020 | 07:18 PM
mitchellhazelton
Got it running on driver side injectors and glow plugs now the other side I unplug it and it acts the same nothing changes like none of it is working. Maybe I need to pull of the valve cover and replace the gasket with all the wiring?
Old Apr 8, 2020 | 07:28 PM
SkySkiJason
At least do the $0.52 mod.
Old Apr 9, 2020 | 09:32 AM
bsiliani's Avatar
bsiliani
Miss that guy Ron.
He makes it look like a child can fix my truck by following his lead.
Old Apr 11, 2020 | 07:30 PM
blageurt's Avatar
blageurt
I would look at the condition of the connector first ..If you see the insulation on the wires is not pristine it is a sure bet that you need to replace the connector..I soldered and heat shrunk mine but the kit I bought from Ford had crimping style connectors that you could also use..I wold also heat shrink those . I also had to replace the gaskets due to burn out at the pins that the connector connects through.The newer gaskets do not come loose like the old ones so you don't need the quarter anymore.... I reccomend OEM parts ...https://k-mansparts.com/ .. .Good Luck
Old Apr 12, 2020 | 06:30 AM
SkySkiJason
Automotive industry experts recommend crimp connectors over soldering for the most reliable repair.
I use uninsulated crimp connectors and double wall shrink tubing for repairs like this. Always stagger the connectors so you don’t have a big bundle of them in one place.
Tperez
Apr 9, 2020 05:58 PM
Hitagain
WTB - Parts & other
Apr 10, 2015 04:55 PM
jd58980
Apr 20, 2010 06:34 AM
shark1979
20
Mar 31, 2009 04:03 PM
BlackIce
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Feb 26, 2002 11:11 PM
