Sponsored by: Real Truck
O/D light flashing
Old Apr 4, 2020 | 01:24 PM
Superstarr474's Avatar
Superstarr474
O/D light flashing
I have a2002 f350 with the v10. My problem is that the od light is flashing and has no power when shifted into either a forward gear or reverse. Runs great in neutral and park. Put new solenoid pack in tranny and still have same problem. The problem started after I installed a new fuel pump. Truck ran perfect before that. If anyone has any suggestions please help.
Old Apr 4, 2020 | 05:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The ONLY way to fix this is to read the codes. Without the codes, all you can do is waste money buying parts like solenoid packs. Why would you spend all that money without knowing that the solenoids are the problem? If you had the codes it would point you right at the problem.
The places that read codes free CANNOT read these codes. You need Forscan, or a good independent shop, or a Ford dealer to read the codes.
Old Apr 5, 2020 | 09:06 PM
Superstarr474
I replaced the solenoid pack after I had talked to who I thought to be reliable sources. Guess I was wrong.
Sara_gael
May 15, 2017 11:10 PM
RDockery
Apr 21, 2016 08:50 PM
drembedded
22
Aug 17, 2011 09:43 AM
cmiller1229
Mar 12, 2010 07:33 AM
woodduck17
Jul 29, 2009 10:48 AM
