Which tranny? And problem
Old Mar 2, 2010 | 08:45 PM
cmiller1229's Avatar
cmiller1229
How do I know which tranny is in my 1996 F250 4x4 7.3L Truck? All I know is that it's an automatic.
It had started to shift hard, the off button on gear selector lever blinks.
I was told that it goes into "limp mode"?
Can someone give me the full 411?
Old Mar 2, 2010 | 08:58 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's an E4OD. When the OD OFF light flashes one or more codes were stored in the PCM. You need someone with the right scan tool to read the codes. The parts stores that read codes free can't read the transmission codes. Without the codes you won't know what's wrong.
Old Mar 2, 2010 | 09:12 PM
cmiller1229
Where do I take it to find the codes?
Old Mar 3, 2010 | 10:49 AM
Mark Kovalsky
1996 is a tricky year for those. They are or are not OBDII. I've never had a straight answer on that one. A good independent shop, and of course a Ford dealer, would be able to read the codes.
Old Mar 3, 2010 | 02:22 PM
cmiller1229
Went to a local tranny shop. Cost me 35.00 to get these.
Codes:
P0113
P1748
P0236
P0605
P1746
Old Mar 5, 2010 | 08:07 PM
Mark Kovalsky
P1746 and P1748 both mean the pressure control solenoid has a problem. Either the solenoid is bad or the wiring to the solenoid is bad. A few minutes with a meter will show which one is bad.
Old Mar 9, 2010 | 08:10 AM
cmiller1229
Which Transmission Fluid do I use?
How bad is 1 Qt too much?
I had to drain 1 qt out to get correct level. It's been in there for 6-7 mos. not knowing it was overfilled.
Old Mar 9, 2010 | 11:29 AM
Mark Kovalsky
Use any brand with a MERCON V rating. Overfilled is just as bad as underfilled.
Old Mar 9, 2010 | 01:11 PM
cmiller1229
I now have the correct level.
Transmission's 1st and 2nd gear shifts hard., Transmission still has same codes.
Old Mar 9, 2010 | 06:33 PM
Mark Kovalsky
The wrong fluid level won't set any of those codes.
Old Mar 12, 2010 | 07:33 AM
cmiller1229
A different shop told me it might me the. . . . Cam Sensor?
skillykat
Jan 15, 2015 12:47 AM
SchaefferUSMC
Sep 4, 2010 08:11 PM
truck2nv
1983 - 2012 Ranger & B-Series
Oct 13, 2007 09:17 PM
turnsonadime
1978 - 1996 Big Bronco
Feb 28, 2004 10:54 PM
nissanjon
Jul 8, 1999 10:40 AM
