Transmission possible filter drop
Old Mar 29, 2020 | 07:57 PM
PagosaFord's Avatar
PagosaFord
I have a 1992 f150 e40d. I've had it for several years. Getting ready for a lengthy road Trip. I suspect the tran filter dropped. What are the symptom of this condition. I go from park to reverse and and it hesitates for a few second before It pressurized, and the same from reverse to drive. Is this normal. I don't remember I haven't thought about it till, I started prepping for up coming trip. It runs and shift fine. Is it normal for The e4od. Thanks
Old Mar 30, 2020 | 06:56 AM
sandymane's Avatar
sandymane
I have read where a dropped filter can cause issues like you describe. If you have recently changed fluid and filter that is a good possibility. A loose fit on the filter seems fairly common. I have read where the Wix and Motorcraft fit snug. Also the old oring could still be in there causing a loose fit. Regardless, I would drop that pan before taking a long trip. You can run diagnostic codes and/or pull the PCM lastly to check capacitor conditions. Sandy
Old Mar 30, 2020 | 08:05 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I suppose that could have happened but I doubt it. Have you checked the fluid level?
Old Mar 31, 2020 | 04:27 PM
PagosaFord's Avatar
PagosaFord
Yes that was the first thing you I did, it's not a real big deal. I just don't remember. If that works a normal for the E40d. At my age the memory is the first thing to go. Yes I don't want to be 1k away from home and have issue. Thanks for your response.
Old Mar 31, 2020 | 05:46 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Normal engagement times for the E4OD is 2-3 seconds.
If the filter fell out you will have slipping in all gears, not just engagement times.
Old Mar 31, 2020 | 07:15 PM
PagosaFord's Avatar
PagosaFord
Thanks alot for your response, I have a normal operating trans.
95F150RLP
Jul 7, 2017 05:00 PM
tmt217
13
Jan 18, 2014 07:16 PM
IDIDieselJohn
Jan 21, 2011 05:11 PM
firstcomesl
Apr 19, 2007 07:42 AM
boonie
Feb 13, 2007 06:01 PM
