I have a 95 f150 4x4. With a 5.0 an E4od f
when I try an run a KOER the check engine light flash 4 times then once. It will rev up for about 45secs then idles down but starts popping sounding like a backfire from the exhaust before the check engine light even flash for you to hit the throttle.
Any help would be awesome
